Suspension & Brakes Theory, alignment, spring rates....
CRX Suspension Build-Up
Old Apr 5, 2007 | 12:45 PM
2ndJen's Avatar
Default CRX Suspension Build-Up
Alright this is my first write-up ever... From what the title says I am going to start a complete tear down and build of my suspension. I'll post the progression. I think this could be easily done in few days, but I'm not going to. I'm not in a rush and I don't have a lot of extra time to do this. So it will be a slow progress, but I figure I could get lots of feedback, suggestions and comments during the build. I'll get some pics up soon...
This is what I got so far:
Front:
new OEM LCA bushings
new OEM Wheel Bearings
new OEM Lower Ball joints
used UCA with Ingalls camber kit [from my old si]
new OEM bolts all around ( hey why not, might as well )
used HF sway bar and Si sway bar
new OEM tie rod ends
Rear:
new OEM Type R Lower Control Arms ( should I get 88 si LCAs instead? )
new OEM Compensator Bushings
new OEM TA bushing
This is what still needs to be ordered
Front:
Bushings for Radius Rods (Prothane, ES or OEM?)
Bushings for Sway bar (Prothane or ES?)
Koni Sport(ordering with the GCs)
GC (haven't determined a spring rate)
GC tophats
Quaife Steering rack
Steering rack end bushings
Rear:
Suspension Techniques 7/8" Sway Bar
(interested in the Progress 24mm adj bar, but the ST has a kit for 88's)
Ingalls camber kit
First question, Is 2mm more of sway bar worth it for the Progress bar? If so I'd have to get 89 n up LCA and bushings. If i remember correctly, they have a kit for STD model civics that did not come with a sway bar. Or does mount up like the STs with the tow hooks.
sofakingquick
Suspension & Brakes
Dec 24, 2011 07:26 PM
Biggmike92vx
10
Jun 3, 2007 09:06 PM
clarkekent13
Suspension & Brakes
Jul 25, 2005 07:57 PM
EGO
Jun 25, 2003 10:55 PM
