Need help finding a AUTOMATIC ECU
Old Apr 5, 2007 | 12:14 PM
MiX's Avatar
MiX
Default Need help finding a AUTOMATIC ECU
i need an automatic obdII ecu to run a b18c?
any possible suggestions? or alternatives.
Im trying to keep this as simple as possible and want to run obdII for emissions.
Old Apr 5, 2007 | 12:30 PM
MiX's Avatar
MiX
Default Re: Need help finding a AUTOMATIC ECU (MiX)
also can i use a tcm from a obd1 or does that have to be obd2 also?
Old Apr 5, 2007 | 08:22 PM
GOTSUBZ's Avatar
i would go down to a junkyard and search for one or find someone with a parts car and get it off of them.
Old Apr 5, 2007 | 08:56 PM
onesikdb8's Avatar
OBD2a or OBD2b?......If you get the actual JDM ECU, the emissions station won't be able to retrieve information using the scanner to the DLC.
Robinsons
Apr 5, 2017 04:07 PM
Pimpsherm2009
Jan 13, 2010 06:05 PM
eater_eg6
Dec 12, 2005 12:54 AM
VTECPowerdSi
Oct 16, 2004 04:20 PM
