1996 honda del sol headlights
What kind of troubles? For the bulb? If so most hondas you have to unfasten the wiring harness, then the clips that hold them down, then the plastic piece covering the bulb, then remove. Replace the bulbs and do it backwareds. If for the whole headlight assembly, just look for the screws and fastners holding it down. Should be pretty easy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennett_138 »</TD></TR><TR><TD CLASS="quote">I need help changing the drivers side headlight. i'm having troubles.
if you take off the bumper all the 10mm bolts will be visable
</TD></TR></TABLE>if you take off the bumper all the 10mm bolts will be visable
SOHCIT
May 11, 2010 11:16 AM
