Best street VTEC head setup? LS/VTEC
I've been kicking around the idea of taking the built LS head off my motor and going with a vtec head so that I can have some street-ability back. I like the rediculous low end torque, but feel that i can sacrifice it for a more sound setup.
All the bottom end has is CTR .010" over pistons on stock ls rods/crank. I'm looking for something cheap of course, but with the best mid i can get. Topend isn't a concern since the bottom end wont spin it.
Just scratchin my head...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gearhead313 »</TD></TR><TR><TD CLASS="quote">I've been kicking around the idea of taking the built LS head off my motor and going with a vtec head so that I can have some street-ability back. I like the rediculous low end torque, but feel that i can sacrifice it for a more sound setup.
Just scratchin my head...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 »</TD></TR><TR><TD CLASS="quote">I suggest you replace the rod bolts with arp rod bolts and spin that puppy to stock vtec redline anyway... Use a vtec head with m22's or the like, you wont be let down</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper »</TD></TR><TR><TD CLASS="quote">If you arn't looking for a top end shift why both swapping even ?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude »</TD></TR><TR><TD CLASS="quote">
? ? ?</TD></TR></TABLE>
He stated he didn't want to spin more rpms or gain extra top end, so I'm asking why swap out to a different head..
His post is a jumble but it sounds he's quite happy with his setup.
wow, ya i re-read that and im even confused...
My LS head = crower 404's, springs/retainers, skunk2 pro cam gears, ITB's, RC370cc, cheapo header.
Its basicly an autox motor. I just put a cometic headgasket on it to take it from 13.1 to 12.2 cr. It lost some of its umph and its just not as fun.
I know a vtec head will ultimately flow much better, even if i hard limit the motor at 7800rpm.
I'm looking for an all around setup that has good street mannors with the best bottom end feel.
That would include cams, TB/intake mani or another set of ITB's, springs/retainers or not (I assume not), rough cam gear setting and maybe a better header.
Everywhere I read, people are looking for big top end power. I would rather have an average peak, but with the flattest curve. How can this be done?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude »</TD></TR><TR><TD CLASS="quote">what are the specs on the crower 404's</TD></TR></TABLE>
from crower.com:::
intake / exhaust
adv dur: 276 / 272
dur @ .050": 226 / 224
lift: 445 / 434
from crower.com:::
intake / exhaust
adv dur: 276 / 272
lift: 445 / 434
From: From the East side, and loving the West side, UnitedStates
i wouldnt mess with those crowers, junk!! i would stick with like skunks, buddys, toda b's you want too pay for quality you dont want junk. im just lookin out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gearhead313 »</TD></TR><TR><TD CLASS="quote">Everywhere I read, people are looking for big top end power. I would rather have an average peak, but with the flattest curve. How can this be done?</TD></TR></TABLE>
JRSC would be a great start
As far as NA cams go, there isn't much other choice. they have good profiles and have been around for ever. If 2 or 3 stories of how they failed scare some people, then thats fine for them to stay away. I'll run what profiles I like till they fail and then join the mob!
I'm not a big fan of JRSC's. First, I have too much compression to start bolting a blower onto the thing. Plus, I'd turbo all day long before i'd SC... this is an NA motor.
you might dabble with the Rocket non-vtec cams, the L21s. 262 degress@10.2mm on intake and exhaust side. just my .02
If your set on a VTEC head, I am prone to the PR3. Tends to flow better than the P72 head. There is a reason why it is used on both Type R motors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by outtacontrolsol »</TD></TR><TR><TD CLASS="quote">
If your set on a VTEC head, I am prone to the PR3. Tends to flow better than the P72 head. </TD></TR></TABLE>
if by better you mean nearly the same, yes.
the only reason i'd grab a pr3 is b/c they are cheap.
I'll have to sell my current head setup now to fund the vtec head swap. I bet thats going to be tough to sell...
and what reason is that?
</TD></TR></TABLE>and what reason is that?
to be honest...the vtec head and stock/type-r cams might make more hp than your current set up
just get a vtec head and aftermarket valve springs+retainers from a good company like super tech etc
then you can run whatever cams you chose. i would pick pro 1's if your staying
around a stockish 7800 rpms or bc+3 etc.
big lobe specs?
I've also been told that just a stock head could probably make the same, probably more power than the ls head setup on it now.... which makes me sad, i put all that time and money into the valvetrain and making the ITB's.
i would say that you change pistions to
ctrs are kinda high cr for street but you probly needed them with the ls head
edit:
what was whp of the ls head setup and got any pics of the home made itbs
edit:
