Suspension for a 5th gen Prelude
Old Apr 5, 2007 | 08:24 AM
Tunerguy1989's Avatar
Default Suspension for a 5th gen Prelude
what kind of suspension would work for an 98 prelude Sh, everywhere I've looked they exclude sh models, what should i do.
Old Apr 5, 2007 | 08:29 AM
lenn's Avatar
Default Re: Suspension for a 5th gen Prelude (Tunerguy1989)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tunerguy1989 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of suspension would work for an 98 prelude Sh, everywhere I've looked they exclude sh models, what should i do.</TD></TR></TABLE>
You should use the search button....
https://honda-tech.com/zerothread?id=1448005
Old Apr 5, 2007 | 09:17 AM
Flex'n Da Lude's Avatar
Default Re: Suspension for a 5th gen Prelude (lenn)
^+1 on the search function... neuspeed.com also.
Old Apr 5, 2007 | 10:09 AM
Hirousuke's Avatar
The SH and base models use different struts and springs so you cant mix and match. You cant just buy a new set of struts and use the stock springs or vice versa. However if you replace the entire assembly, i.e Koni Yellows + Ground Control coilovers, then you can use the base parts, they bolt on just the same.
Old Apr 5, 2007 | 02:48 PM
shhh151's Avatar
Default Re: Suspension for a 5th gen Prelude (Hirousuke)
as long as you change the shock and springs you can buy any aftermarket base model shock and springs
DelSol12345
Dec 31, 2010 11:51 AM
getsuummm
Nov 29, 2007 09:05 PM
96Civic_Coupe
Jun 4, 2007 07:03 PM
crznlo
Oct 30, 2003 03:39 PM
MugenPoweredLude
Nov 5, 2002 07:04 PM
