Black smoke from exhaust?
Old Apr 5, 2007 | 07:09 AM
sixtodc2's Avatar
Default Black smoke from exhaust?
yeah the other night me and a couple of buddies where going to some car meet . when i was going to the car meet and heading to the freeway everything seem normal to me then after we got off the freeway ny friend said that a lot of black smoke came out of my exhaust when i enterd the freeway. He told he each time i would shift my gear a dark smoke would puff out !.
Yeah my car is a 01integra ls?>
Old Apr 5, 2007 | 07:15 AM
Sam92Teg's Avatar
Default Re: Black smoke from exhaust? (sixtodc2)
How many miles on motor and any oil consumption?
Old Apr 5, 2007 | 07:21 AM
sixtodc2's Avatar
Default Re: Black smoke from exhaust? (Sam92Teg)
well i got a oil change not that long ago.. well i only have 83000k. yeah i even check my oil and it was fine ?
Old Apr 5, 2007 | 07:30 AM
hondateg10's Avatar
From: Somewhere in the United States, united states
check the o2 sensor
Old Apr 5, 2007 | 07:36 AM
sixtodc2's Avatar
Default Re: (hondateg10)
i mean the last time i saw my 02 sensor was when i change my header.. they where looking pretty dirty and black. well u think that can be the problem ?
Old Apr 5, 2007 | 07:39 AM
hondateg10's Avatar
yeah i would replace them and then check it out from there
Old Apr 5, 2007 | 07:40 AM
sixtodc2's Avatar
umm so it would not be the spark plugs. ?? by any chance ?
Old Apr 5, 2007 | 07:46 AM
Kingfish714's Avatar
Default Re: (sixtodc2)
No check engine light? Are you loosing any oil? Were you mashing on the throttle?
You may be running a bit on the rich side. How to fix this? I'm not sure. I had this
happened to my sedan. Tested the emissions, everything came out fine. It never gave
me any problems.
Modified by Kingfish714 at 10:06 AM 4/5/2007
Old Apr 5, 2007 | 07:49 AM
hondateg10's Avatar
if you pull you spark plugs see what color they are and i know in the haynes book for mine it show diff. kind of spark plugs and tell you what could be the problem. but it would hurt to pull them and check them out. but o2 are only like $15 at auto zone
Old Apr 5, 2007 | 07:51 AM
Schister66's Avatar
Man U FTW
black smoke is unburnt fuel...
<U> CHECK:</U>
-fuel filter
-plugs
-air filter
-02 sensor (although they only control AF during part throttle)
sixtodc2's Avatar
Default Re: (Kingfish714)
my engine light never came on . my car is running fine.. well yeah the sparks plugs are kinda ashy balck ?
Old Apr 5, 2007 | 07:53 AM
hondateg10's Avatar
yeah i would replace them and the o2 and see if that fixes the problem
Old Apr 5, 2007 | 07:59 AM
mike5809's Avatar
It should have nothing to do with oil.
Check o2 sensors, fuel filter, cat, etc, check your plugs see what color they are.
edit; i see ppl have already told you that, and you have done it.
plugs dont seem to bad if they have alot of miles on them. replace them and cap and rotor while your at it. and o2 sensors. see if it fixes it, if not take ur cat off and inspect it
Old Apr 5, 2007 | 08:02 AM
sixtodc2's Avatar
Default Re: (mike5809)
i still got stock cats on my ride . i havent change it..i need to replace it with a high flow cat !! but to lazy with that !
Old Apr 5, 2007 | 08:05 AM
hondateg10's Avatar
just change you o2 and your problem should go away
Schister66's Avatar
Man U FTW
is your air filter crappy?? Have you been getting bad mileage?? Does your car seem to have less power??
Check those things i listed and you should find your problem....if not, you there is something wrong w/ one of your cats or possibly the EVAP system....although i really doubt the latter
Old Apr 5, 2007 | 08:07 AM
mike5809's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondateg10 &raquo;</TD></TR><TR><TD CLASS="quote">just change you o2 and your problem should go away</TD></TR></TABLE>
Old Apr 5, 2007 | 08:08 AM
sixtodc2's Avatar
Default Re: (Schister66)
well i got an injen intake and the filter is clean ,, well my power is kinda ?? 1st an 2nd its all good a gravy but when i get in third is does not go anywhere??
k20chornicalz
15
Dec 19, 2008 04:34 PM
C00kiemunstr
10
Sep 12, 2008 12:48 PM
PrimeElement
16
Nov 12, 2007 02:39 PM
AlizeVS
Sep 17, 2004 10:51 AM
RallySportCivic
Mar 31, 2003 07:36 PM
