will this rear shim kit work for a 94 Accord Sedan?
Old Apr 4, 2007 | 11:58 PM
edger8cer's Avatar
Default will this rear shim kit work for a 94 Accord Sedan?
Im askin this for a friend thats not a member of h-t,
does this work for the 94-97 5th gen accord?
http://www.inlinefour.com/ompowrearshi.html
I have this setup on my civic and was thinkin it should work as well on the accord but not sure.
also, anyone know wheres the cheapest camber kit for the front? thanks in advance cuz i tried to search but nothing came up.
Old Apr 5, 2007 | 12:05 AM
philadd's Avatar
Default Re: will this rear shim kit work for a 94 Accord Sedan? (edger8cer)
Yes, that will work just fine. You can go to your local hardware store and buy the same exact thing for less than $5 though. You can look in the Accord FAQ, under the suspension section, and go to the "5th gen rear camber washer trick" guide and how-to. It'll tell you what size bolts and washers to get.
Flipmonkey
Suspension & Brakes
Jan 8, 2014 05:39 AM
zumiez007
Jan 7, 2005 10:59 AM
accordgrrl
Jan 11, 2004 06:26 PM
purpl7duece
Dec 3, 2002 01:10 AM
