skunk2 manifold bore size & throttle body
Old Apr 4, 2007 | 10:27 PM
1.8L_allmotormilitia's Avatar
Default skunk2 manifold bore size & throttle body
anyone know the actual bore size of the skunk2 manifold?
going to be running stage 2 cams w/ skunk2 manifold so I'm also wondering what size throttle body will be good w/ the manifold and cams.
Old Apr 5, 2007 | 05:25 AM
IN VTEC's Avatar
Default Re: skunk2 manifold bore size & throttle body (1.8L_allmotormilitia)
The inlet is the same size as the ITR throttle body. But, if you're using a larger throttle body, you can hone it out with a cylinder hone and a drill.
Old Apr 5, 2007 | 06:58 AM
soundFX's Avatar
Default Re: skunk2 manifold bore size & throttle body (IN VTEC)
64mm is the size of the skunk2
Old Apr 5, 2007 | 07:55 AM
formervendor's Avatar
Banned
Default Re: skunk2 manifold bore size & throttle body (soundFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundFX &raquo;</TD></TR><TR><TD CLASS="quote">64mm is the size of the skunk2</TD></TR></TABLE>
He is correct.
B series Manifold = 64 mm Opening
D series Manifold = 62 mm Opening
H series Manifold = 66 mm Opening
These are many other facts can be found in our NEW 2007 E-Catalog. The 2007 Catalog can be found at http://www.skunk2.com
Old Apr 5, 2007 | 09:14 AM
K2sInteg98's Avatar
Default Re: skunk2 manifold bore size & throttle body (Duckiller00)
yup the skunk2 manifold has a 64mm opening. As someone said you can just get a 64mm tb or if you wanna get a bigger tb, just make sure you port match the opening of the manifold so flow is good
Old Apr 5, 2007 | 08:05 PM
cool thanks guys. also whats stock size throttle body?
Old Apr 8, 2007 | 09:09 AM
Satoonxtreme's Avatar
Default Re: (1.8L_allmotormilitia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8L_allmotormilitia &raquo;</TD></TR><TR><TD CLASS="quote">cool thanks guys. also whats stock size throttle body?</TD></TR></TABLE>
I believe its 63mm for Type R, correct me if im wrong
Civicek000
Oct 20, 2016 04:37 PM
YoungMoneySi
Apr 24, 2006 06:56 AM
flat-blk-HB
Jun 9, 2005 03:12 PM
ddong2lee
Mar 13, 2004 05:34 PM
LeftCorner
Sep 12, 2002 12:59 PM
