wheel wobbling help!!!
Old Apr 4, 2007 | 10:05 PM
gosu08's Avatar
Default wheel wobbling help!!!
i lowered my car a feel ago with H&R sports springs and it drove fine for a week until it started to camber then the wheel wobbled really really bad. i got ingalls camber kits installed and then the wobbling got a less but it still wobbles. is it because i need to set the camber as low as possible or because the tow hooks are not straight or something else? on the paper my tow hooks are barely off if not at zero on each wheel.
thanks for the help
Old Apr 5, 2007 | 02:02 AM
shadow_ridge's Avatar
Default Re: wheel wobbling help!!! (gosu08)
when mine wobbled it did it between 0 to 35 mph, I had a bad lower control arm bushing at the end. and my radis rod was lose.
Old Apr 5, 2007 | 07:00 AM
hurleyint's Avatar
Default Re: wheel wobbling help!!! (shadow_ridge)
Tow hooks??? whooaa...
You need your TOE adjusted at an alignment shop. Thats what eats away the inner part of your tires, not camber.
dhonda
May 15, 2011 03:50 PM
zbra09
Suspension & Brakes
Oct 5, 2008 07:41 AM
DarkTeg94
Nov 24, 2004 07:23 AM
