HX Wheels. Rec. Me Some Tires!
Old Apr 4, 2007 | 09:03 PM
SlowPokeEg's Avatar
Mike Jones
Default HX Wheels. Rec. Me Some Tires!
Seems there are limited "nice" tires for 14" rims.
Once you hit 15" the sky is the limit.
What do you guys like for your DD/weekend car?
I'm thinkin 195's to get some more width and prevent bulging.
And since you can't search HX, i made a new post. So direct me in the right direction if you know of another similar post
Thanks HT!
Old Apr 5, 2007 | 04:34 AM
92hatchattack's Avatar
What car are they going on??? You can get some AVS ES100's in 185/60-14 or 195/60-14 depending on your car.
Anyone know how much the HX wheels weigh???
Old Apr 5, 2007 | 04:40 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (92hatchattack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchattack &raquo;</TD></TR><TR><TD CLASS="quote">What car are they going on???</TD></TR></TABLE>
Yup. The proper size depends on the car, not just on the wheels. On 14" wheels, you need 185/60-14 on a del sol, CRX, or pre-'96 Civic, and you need either 185/65-14 or 195/60-14 on an Integra or '97-00 Civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchattack &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know how much the HX wheels weigh???</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1468780
Old Apr 5, 2007 | 05:13 AM
^^^ thanks man. By the way, is there a list somewhere here on H-T with OEM tires sizes and overall diameters just for my future refrence???
Old Apr 5, 2007 | 06:02 AM
excivicboy96's Avatar
I wish I could find HX rims up here in Maine
Old Apr 5, 2007 | 06:05 AM
Default Re: (excivicboy96)
another question I have a 96 civic EX. according to that link it says that my wheels are 185-65/14x5.5 Could I still use the 185 series with HX rims that are 14x5? maybe even go to 195's?
Old Apr 5, 2007 | 07:20 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 &raquo;</TD></TR><TR><TD CLASS="quote">another question I have a 96 civic EX. according to that link it says that my wheels are 185-65/14x5.5 Could I still use the 185 series with HX rims that are 14x5? maybe even go to 195's?</TD></TR></TABLE>
I believe HX rims are 14x5.5 and not 14x5.
For 14" wheels on your car, you can use 185/65-14 or 195/60-14. Either one will work. There are lots more good tires available in 195/60-14 than 185/65-14.
Brief recommendations:
1. If you care ONLY about dry traction, get the Falken Azenis RT-615 in 195/60-14. Supersticky on dry pavement. Downsides include fast treadwear (10-12K mile lifespan is typical) and so-so performance in rain. $61/tire at Vulcan Tire.
2. If you also care about wet traction and treadlife, get the Yokohama ES100 in 195/60-14. Pretty good dry traction, excellent in rain, and last a reasonably long time (25-40K miles). $75/tire at the Tire Rack.
3. Both of the previous recommendations are summer tires and should not be used on snow. If you need to use these tires all year round, including occasional snow in winter, then you need all-season tires. In that case, a great all-season tire is the Bridgestone Potenza RE960AS Pole Position, available in 195/60-14. $69/tire at the Tire Rack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchattack &raquo;</TD></TR><TR><TD CLASS="quote">By the way, is there a list somewhere here on H-T with OEM tires sizes and overall diameters just for my future refrence???</TD></TR></TABLE>
Stickied at the top of this forum is a topic called
Forum Rules and FAQ - READ BEFORE POSTING
It says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules and FAQ - READ BEFORE POSTING &raquo;</TD></TR><TR><TD CLASS="quote">What size tires should I get?
The proper size depends on your car, not just the wheels you are using.
For a CRX, del sol, or pre-'96 Civic, the following sizes are usually best:
13" - 175/70-13
14" - 185/60-14, 195/55-14
15" - 195/50-15
16" - 205/40-16
For an Integra or '97-00 Civic, the following sizes are usually best:
14" - 185/65-14, 195/60-14
15" - 195/55/15, 205/50-15
16" - 205/45-16, 215/45-16
17" - 205/40/17
This is open for discussion and by no means what you have to get, but as a general rule you cannot go wrong with these sizes.
Old Apr 5, 2007 | 09:02 AM
SlowPokeEg's Avatar
Mike Jones
Default Re: (nsxtasy)
EG hatch is what they're going on. Wear is my biggest concern because of cost. Grip would be my second most concern.
Thanks for the replies so far
Old Apr 7, 2007 | 02:19 PM
TypeOneSiR's Avatar
Default Re: (SlowPokeEg)
I'm getting some hx's and I just wanted to know what is the downside of going with a 50 series tire? Also do they make yokohama parada's in 14 inch and ecsta's? I plan on going azeni's up front and parada's or ecstas in the back. I couldnt find any of these tires at the tire rack =x I guess i screwed up somewhere but can anyone give me some feedback on this? thx
Old Apr 7, 2007 | 04:57 PM
94civicCx's Avatar
Default Re: (HolyHondaEmII)
Bump like to know also..
Old Apr 7, 2007 | 08:51 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HolyHondaEmII &raquo;</TD></TR><TR><TD CLASS="quote">I'm getting some hx's and I just wanted to know what is the downside of going with a 50 series tire?</TD></TR></TABLE>
I don't know of any 14" tires with a 50 aspect ratio.
You should be getting tires with the same outer diameter as your stock tires. That's where the sizes above come from.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HolyHondaEmII &raquo;</TD></TR><TR><TD CLASS="quote">do they make yokohama parada's in 14 inch</TD></TR></TABLE>
That's one of the worst tires you can buy for the money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HolyHondaEmII &raquo;</TD></TR><TR><TD CLASS="quote">and ecsta's?</TD></TR></TABLE>
Kumho makes a lot of different tires with the Ecsta name. Some of them are excellent tires. Some of them are crap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HolyHondaEmII &raquo;</TD></TR><TR><TD CLASS="quote">I plan on going azeni's up front and parada's or ecstas in the back.</TD></TR></TABLE>
That's a terrible idea. On dry pavement, your car will oversteer; the back end will want to swing around on you. In rain, your car will understeer; the car will tend to plow straight ahead when you turn the steering wheel. Use the same tires on all four wheels, to avoid handling problems that are the result of mismatched tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HolyHondaEmII &raquo;</TD></TR><TR><TD CLASS="quote">I couldnt find any of these tires at the tire rack =x I guess i screwed up somewhere but can anyone give me some feedback on this? thx</TD></TR></TABLE>
We can provide some recommendations that will meet YOUR needs if you answer a few questions:
- What kind of car are these for? (year, model, version)?
- What diameter wheels?
- What kind of driving do you do? (daily driving, racetrack/autocross)?
- Do you need to use these tires in snow as well as in moderate to warm temperatures?
- Do you care mostly about performance, or do you also care about value (purchase price and treadlife)?
Old Apr 8, 2007 | 04:31 AM
Sikocivic's Avatar
Default Re: HX Wheels. Rec. Me Some Tires! (SlowPokeEg)
These are the tires I am going to be running on my HX wheels.
http://www.1010tires.com/tire....E-512
Old Apr 8, 2007 | 08:04 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: HX Wheels. Rec. Me Some Tires! (Sikocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">These are the tires I am going to be running on my HX wheels.
http://www.1010tires.com/tire....E-512 </TD></TR></TABLE>
Those are crappy tires. If you really need all-season tires (because you will be using the same tires in winter as the rest of the year), the Bridgestone Potenza RE960AS Pole Position is much better in every way, for about the same money. And if you're not using them in snow, the Yokohama ES100 is even better than that.
Old Apr 8, 2007 | 11:39 AM
TypeOneSiR's Avatar
Default Re: HX Wheels. Rec. Me Some Tires! (nsxtasy)
thx nsx...well I have a 96 dx hatch and will be putting HX wheels on it, I'm a student so a lot of daily driving is done and plan on doing some autocross/drag a bit in the future. I live in Florida so it's mainly warm to very hot temps and lots of rain. I care about performance and price...life...well tires all wear out eventually so i know i'm going to replace them eventually but tire life is not that big of an issue. I mean to say Kumho Ecsta SPT i believe they are called...I heard they were good as well as the Es-100. But I have heard nothing but good stuff when it comes to the Azeni's except that they aren't good in the rain. Thanks for the help =D
Old Apr 8, 2007 | 12:28 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: HX Wheels. Rec. Me Some Tires! (HolyHondaEmII)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HolyHondaEmII &raquo;</TD></TR><TR><TD CLASS="quote">thx nsx...well I have a 96 dx hatch and will be putting HX wheels on it, I'm a student so a lot of daily driving is done and plan on doing some autocross/drag a bit in the future. I live in Florida so it's mainly warm to very hot temps and lots of rain. I care about performance and price...life...well tires all wear out eventually so i know i'm going to replace them eventually but tire life is not that big of an issue. I mean to say Kumho Ecsta SPT i believe they are called...I heard they were good as well as the Es-100. But I have heard nothing but good stuff when it comes to the Azeni's except that they aren't good in the rain. Thanks for the help =D</TD></TR></TABLE>
I would get the Yokohama ES100 in 185/60-14* for your '96 Civic DX hatchback. The SPT is very good but it isn't available in 14" sizes, so it's not an option for those wheels. The Azenis offers great traction on dry pavement but the bigger downside (besides wet traction) is that they only last 10-12K miles, compared with 25-40K miles for the ES100 and SPT.
* Note that I am recommending a different size for your '96 Civic DX hatchback from the other fellow's '96 Civic EX. That's intentional. It's because in '96, the DX and hatchback models had smaller stock size tires than the other Civic models.
Old Apr 8, 2007 | 01:20 PM
Sikocivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Well you may not like them but alot of other people do.
Old Apr 8, 2007 | 06:37 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">Well you may not like them but alot of other people do. </TD></TR></TABLE>
I bet you none of them have also tried summer tires (just about ALL of which are better than all-seasons) or the best all-season tires available (Kumho ASX, Bridgestone RE960AS, Pirelli PZero Nero M&S, Avon Tech M550AS, Michelin Pilot Sport AS).
That's the problem with information like in the Tire Rack's "user survey results". People who buy the same crappy tires, set after set after set, give them good marks because they've never tried anything better.
By comparison with many other tires you can get for the same money in most sizes, the Falken Ziex ZE-512 is CRAP. And there are lots of other people who know it, too (in this and other forums).
Apotheosis
Oct 8, 2008 02:45 PM
Xecutive
Oct 29, 2007 10:10 AM
92civicfreak
Jun 24, 2006 04:46 PM
Basically
11
Nov 23, 2004 10:14 AM
