Any body painted a front lip?
Old Apr 4, 2007 | 07:54 PM
Integra_drk's Avatar
Default Any body painted a front lip?
So im in the process of painting/ doing bodywork on my car and I was wondering what to do with the front lip. Its the comptech ITR replica. I just figured it might need different prepping since its polyurethane. Anybody have any tips for prep? anything special to do to keep it from chipping? thanks.
Old Apr 4, 2007 | 08:29 PM
Markland Photo's Avatar
search
Old Apr 4, 2007 | 08:53 PM
-dSoc- soccerwuedo5's Avatar
Default Re: (bulletspastsunset)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bulletspastsunset &raquo;</TD></TR><TR><TD CLASS="quote">search</TD></TR></TABLE>
While that was ever so helpful, I happen to be researching the same thing and came across this--&gt;
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QuikSOHCZC &raquo;</TD></TR><TR><TD CLASS="quote">[When painting something made of polyurethane]dont u have to use sum kind of special primer? like bendable stuff? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">Yes you do. What it does is open up the pores in the urethane and remove some of the oils in it. This allows the primer to get into all the little bits of the bumper on a microscopic level and almost get absorbed by the bumper. This primer is also flexable which will minimise if not eliminate the chipping of the paint when going through temperature changes or from normal driving. It looks to me that they used a non urethane specific primer and that is why it looks like that.
CRX Forum</TD></TR></TABLE>
If YOU find any more info, lemme know, k?
Old Apr 4, 2007 | 08:56 PM
simonsays's Avatar
New User
high grit sand paper and Duplicolor Trim paint perfect
Old Apr 4, 2007 | 09:20 PM
Default Re: (simonsays)
soccerwuedo5 and simonsays, thanks a bunch guys! very helpful!
Old Apr 4, 2007 | 11:43 PM
Default Re: (Integra_drk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_drk &raquo;</TD></TR><TR><TD CLASS="quote">soccerwuedo5 and simonsays, thanks a bunch guys! very helpful!
What we're here for
Old Apr 5, 2007 | 12:45 AM
immalooser's Avatar
Default Re: (soccerwuedo5)
http://carbodywork.blogspot.co....html
Old Apr 5, 2007 | 12:53 AM
Rayz_Si's Avatar
From: Land of the Hillbillies and Shotguns, Ontario, Canada
Default Re: (immalooser)
Here is thread you needm you'll hear about the problems and mistakes, and how i made the right choices to make a perfect finished product https://honda-tech.com/zerothread?id=1782413
Learn how to spray paint before if you don't know how, practice on a junkyard fender or a scrap peice of metal. always start spraying before the object, end spray after object. Do not stop in the middle or you'll have a spray line not a smooth coat, move your arm following the curvature of the lip, do not move your wrist pretend ypour arm is in a cast. Industry standard always is atleast 2 coats of color, 2 coats of clear.
Old Apr 5, 2007 | 06:17 AM
Default Re: (Rayz_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rayz_Si &raquo;</TD></TR><TR><TD CLASS="quote">Here is thread you needm you'll hear about the problems and mistakes, and how i made the right choices to make a perfect finished product https://honda-tech.com/zerothread?id=1782413
Learn how to spray paint before if you don't know how, practice on a junkyard fender or a scrap peice of metal. always start spraying before the object, end spray after object. Do not stop in the middle or you'll have a spray line not a smooth coat, move your arm following the curvature of the lip, do not move your wrist pretend ypour arm is in a cast. Industry standard always is atleast 2 coats of color, 2 coats of clear.</TD></TR></TABLE>
cool thanks man, i actually read your thread after i posted this.
slayersluck
11
Jun 7, 2008 10:34 AM
acura_el2000
Jul 10, 2007 02:15 PM
eg_civic209
Oct 21, 2006 11:24 PM
hale_image
Aug 1, 2005 06:39 AM
anekin007
Sep 27, 2004 03:33 PM
