what suspension are you running on your boosted car
Old Apr 4, 2007 | 05:17 PM
ghostofnyc's Avatar
Default what suspension are you running on your boosted car
im looking for a good suspension spring/strut, coilover/ strut, full coilover, im looking for opinions on all three setups something thats gonna be ok for daily driving on occasions not too much squat (but not as solid as a rock either) under hard acceleration good handling
Old Apr 4, 2007 | 05:34 PM
platinum00's Avatar
Default Re: what suspension are you running on your boosted car (ghostofnyc)
Ground Control and Koni Yellow adjustable 350f/450r
platinum
Old Apr 4, 2007 | 05:35 PM
jep's Avatar
jep
Default Re: what suspension are you running on your boosted car (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">Ground Control and Koni Yellow adjustable 350f/450r
platinum
Ive heard nothing but great things about this setup. how much can I get a set of koni yellows for?
Old Apr 4, 2007 | 05:41 PM
RedR's Avatar
Default Re: what suspension are you running on your boosted car (jep)
Eibach aluminium coilover 16k F 12k R
Old Apr 4, 2007 | 05:50 PM
Sprockets's Avatar
Ground Control coilovers (420/420) w/Koni Yellows and Energy Suspension's master urethane bushing kit. Just don't hit any potholes and you'll be fine.
Old Apr 5, 2007 | 04:06 AM
ghostofnyc's Avatar
anymore options
Old Apr 5, 2007 | 04:22 AM
BoostedEG6's Avatar
Default Re: what suspension are you running on your boosted car (Sprockets)
Skunk 2 coilovers w/Koni Yellows and the skunk 900lbs in the rear
Old Apr 5, 2007 | 05:35 AM
blackeg's Avatar
Default Re: what suspension are you running on your boosted car (BoostedEG6)
wow 900lbs is pretty stiff.
i used to run h &r race springs and kyb agx's making 300-350whp and it wasnt too bad. new setup i got some tein basics, gonna test that out soon...
Old Apr 5, 2007 | 05:39 AM
Schister66's Avatar
Man U FTW
Skunk2 coilovers and KYB shocks.....i'm going to make a switch to Konis once i have more money though....
Old Apr 5, 2007 | 07:25 AM
b18sihatch's Avatar
One off Sway-A-Way Race Runner full aluminum bodied rebuildable coilovers with 200PSI Nitrogin Ports.
Hardcore DRAG/Race Sway-A-Way Spring System
1200lbs/Front
2000lbs/Rear
Modified by b18sihatch at 9:35 AM 4/5/2007
Old Apr 5, 2007 | 07:41 AM
JDMRice's Avatar
Default Re: what suspension are you running on your boosted car (b18sihatch)
PIC 12k 10k
Old Apr 5, 2007 | 07:55 AM
tegasaurus's Avatar
Default Re: what suspension are you running on your boosted car (JDMRice)
omni power coilovers 10k/8k (559lb/447), i was making about 250whp on an LS.
Old Apr 5, 2007 | 08:52 AM
lambertincorp's Avatar
Default Re: what suspension are you running on your boosted car (tegasaurus)
any 60 ft times with these setups?
Old Apr 5, 2007 | 08:58 AM
boostedcivicsir's Avatar
Mr. Badwrench
progress drag.....
Old Apr 5, 2007 | 09:05 AM
Turbocivic94's Avatar
KYB with skunk 2 coilovers
Old Apr 5, 2007 | 09:11 AM
SovXietday's Avatar
platinum
x2
Old Apr 5, 2007 | 09:31 AM
HYREV2NR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">omni power coilovers 10k/8k (559lb/447), i was making about 250whp on an LS.
</TD></TR></TABLE>I think I'm going w/ the Omni's next go-round. BTW thats a smokin' clean looking LS man! Tinted windshield?
Old Apr 5, 2007 | 11:54 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: what suspension are you running on your boosted car (lambertincorp)
i had koni yellows with ground control coilovers something like 400 front 5something rears and was able to pull 2.0's with kuhmos
but by far the best thing i did for my 60ft was to get stiff engine and tq mounts
Old Apr 5, 2007 | 12:00 PM
Rooftop voter's Avatar
Default Re: what suspension are you running on your boosted car (coptzer)
I just got some Omni powers, I'll let you know how I like them on Monday.
Old Apr 5, 2007 | 01:26 PM
I Have an STD's Avatar
wrenchin'
Default Re: what suspension are you running on your boosted car (Rooftop voter)
Ground control OTS teg coilovers and kyb agxs. 2.0 60ft times on 205/50/15 kumho 711s.
Old Apr 5, 2007 | 01:47 PM
juda7's Avatar
F2 (Function)
400f 800r
Buckle up......please
Old Apr 5, 2007 | 02:39 PM
96 GSR-T's Avatar
My boy runs the Skunk2 Drag setup with 1000's in the rear in an EG. Really stiff but dangerous to oversteer and things like that on the street.
Old Apr 5, 2007 | 02:50 PM
b18sihatch's Avatar
Default Re: (96 GSR-T)
i imagine if his 1000s are bad those spare SWAY-A-WAY 2000 rears must be insane, my car has eibach springs on them now, but the drag springs i have are for obviously drag purposes.
i cant imagine how those would feel with 1200s in the front and 2000s in the rear.
im also running full energy suspension bushings,comptech rear trailing arm,rear and front strut bar,6 point roll cage....all this in a FULLY gutted 91 CIVIC ef AHAHAHAHAHAHAHAHA
also running LSD,SLICKS & TRACTION BAR so i think when the setup is all done it should be A1 insane
im also looking to make 650whp with my setup too, probably some streetable issues with something that stiff
Old Apr 5, 2007 | 03:21 PM
vtecspeed1320's Avatar
Shooting Star
Yeah I have omni power drag coilover setup...havent gotten to ride around on it yet...ill let you know though how it goes. But for a street car cant go wrong with the gc/ koni yellow setup mentioned above 450/350
Old Apr 5, 2007 | 03:42 PM
BLaCKWiDoWSi's Avatar
what does the 350f/450r mean? is that the spring rate? or does that have something to do with the koni's?
