Lock out of tranny, squeeking from tranny*searched*
Hopeing someone can shed some light on the situation before i get down and dirty ripping parts off the car:
situation is, 1994 GSR motor and tranny. Stock clutch/P.P./Flywheel.(only a year and 1/2 old) One day, driving home ( not freeway), i just gave a slight rip through second gear then slowed down to pull into the gas station. Clutch peddle went in then i released it to drive up into the gas station in second gear. Turned off car, put gas in car, started, and heres the problem:
Now the Car wont go into gear. Locked out of every gear WHEN motor is running. Turn it off, things are fine. Peddle is a bit soft. BUT i have bled the whole system through. found LITTLE air, but got it out.
Also, when starting the car, the letting it idol, with the clutch peddle out, theres a squeeking coming from the tranny area. ( doesnt happen when peddle is pushed in )...Any insite (yes ive searched) to what it COULD be, before i actually rip the tranny off. Im guessing the possiblity of the slave dieing out OR the clutch might be gonners. The clutch MC is about a year old too.... ???
blueeg
Dec 7, 2003 05:49 PM
