Milling Questions
Old Apr 4, 2007 | 02:46 PM
Fasthtch's Avatar
Default Milling Questions
I have a gsr in a eg and im trying to find a cheap way to increase hp.. I have the head off at the moment, n my local machine shop charges $45 to mill a head. How much should i shave off the head to gain some power and how hard is it going to be 2 do the timing without adjustable cam gears??
Old Apr 6, 2007 | 01:39 PM
Lubo_25's Avatar
Default Re: Milling Questions (Fasthtch)
just leave it alone...
Old Apr 6, 2007 | 06:55 PM
soulpwr's Avatar
take 40 thou off. Just remember that once its gone, its gone.
Old Apr 16, 2007 | 10:11 PM
Fasthtch's Avatar
Default Re: Milling Questions (Lubo_25)
ha iwish i would of listened iwent ahead and milled it .20 now i cant get the timing right. I have it set up with gsr base timing and knw i cant get the ignition timing right. i have the dizzy all the way advanced (turned toward the firewall) and its real sluggish and idols horrible which way should i jump the teeth on the cam timing????
Old Apr 16, 2007 | 11:39 PM
Combustion Contraption's Avatar
I think you mean .020, i sure as hope to hell you didnt mill it .200 . Anyway, youre probably just not getting adequate belt tension or something, or it had been previously milled and you went way past the service limit. Did you measure the head?
Old Apr 16, 2007 | 11:48 PM
salman's Avatar
i dont think the gain will be worth it...
Old Apr 16, 2007 | 11:55 PM
Default Re: (salman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">i dont think the gain will be worth it...</TD></TR></TABLE>
READ THE THREAD, HE ALREADY DID IT
Old Apr 17, 2007 | 11:31 AM
Fasthtch's Avatar
Default Re: (Combustion Contraption)
mybad i meant .020.. i have a 98 gsr n a eg do i still need 2 jumper the 2p pin when doing the ignition timing???
integrawow
Engine Management and Tuning
Jan 14, 2009 08:49 AM
gATOr65
Dec 27, 2005 02:03 PM
DcWest
Sep 27, 2005 12:49 PM
scUba-stEve
13
May 15, 2005 08:47 PM
vtecmike1
May 13, 2004 08:25 PM
