HId problem
i got McCollouigh HID's
and i am wondering if one side is brighter than the other side normal and
when u have HID's ,,you soppose to have low and high beams..cuz i seem to have only low beams...
any ideas?
any ideas?
there shouldn't be a difference in brightness between sides and the reason you only have low beans is because you probably only bought the single kit they have a high-low kit that has both high and low beams but usally ony have low
I think your headlights were aimed wrong to begin with.
On the headlight housing there are nuts/bolts with which you can ajust the aim of your headlights.
I suggest doing this at night, parking your car with the lights on about 20-25 ft from a flat wall and adjusting your headlights to where minimal glare is at the top (above 5ft) and the beam pattern is level.
theeogflip
14
Mar 16, 2008 08:56 PM
ley
Honda Civic (2001 - 2005)
Mar 13, 2007 11:22 PM
