which valve cover to use for a zc?
Old Apr 4, 2007 | 12:54 PM
hondasaurusrex's Avatar
Default which valve cover to use for a zc?
i've got a dohc zc im throwing in my 89 crx si, and i need to know which valve cover to use...i got one from an ls, but im not sure it will work...any advice?
Old Apr 4, 2007 | 02:09 PM
JT2MA71's Avatar
88-89 integra d16a1 should fit.
Old Apr 4, 2007 | 02:16 PM
89efDUSTY's Avatar
Default Re: (JT2MA71)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JT2MA71 &raquo;</TD></TR><TR><TD CLASS="quote">88-89 integra d16a1 should fit.</TD></TR></TABLE> probably x2
LS i dont think so
Old Apr 4, 2007 | 02:31 PM
JT2MA71's Avatar
You use a 88-89 integra d16a1 valve cover gasket for the DOHC ZC, so I'd like to think the VC is the same....
not 100% sure it will fit, so you may want to try before you buy.
Old Apr 4, 2007 | 02:51 PM
Crx Jimmy's Avatar
I dont think this is right, i think the zc is different, I have a 87 integra cover which I think is the same as a 88 and it looks different
Old Apr 4, 2007 | 02:59 PM
89efDUSTY's Avatar
Default Re: (Crx Jimmy)
to be honest the holes seem like they would line up close...but i think the only safe option"if applicable" is find a DOHC ZC VC.
Old Apr 4, 2007 | 03:14 PM
JT2MA71's Avatar
Ok did some digging around for you.
a d16a1 VC will NOT work. It uses the same gasket, but the mounting studs are in completely different locations.
You will need a valve cover from a Black Top dohc zc.
The older brown top zc's (that the d16a1 cover fits) will not work.
This is a brown top/d16a1.
http://www.fourthgenhatch.net/...p.jpg
Old Apr 4, 2007 | 03:33 PM
alright....cuz i picked up the ls vc for like 10 bucks, so its officially for sale if ya'll want it, lol....
also for the zc swap, i've heard a lot of people tell me that i need to run a different ecu, like a pm7 or pg7, but im wondering if the factory ecu will work???
Old Apr 4, 2007 | 03:49 PM
Donkey85's Avatar
Default Re: (hondasaurusrex)
yes the pm6 stock ecu will work but wont run near as good as it would with a pm7 or pg7, those have the more aggressive air/fuel maps for that motor
Old Apr 9, 2007 | 09:10 PM
Dev15Bizz's Avatar
Default Re: which valve cover to use for a zc? (hondasaurusrex)
i have a jdm dohc zc valve cover.... still need one?
Old Apr 10, 2007 | 04:36 AM
Johnny G's Avatar
Default Re: which valve cover to use for a zc? (Dev15Bizz)
get a rare EDM rover one.. i can do one for $150 shipped
Old Apr 10, 2007 | 05:16 AM
ludesrv's Avatar
Default Re: (Donkey85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">yes the pm6 stock ecu will work but wont run near as good as it would with a pm7 or pg7, those have the more aggressive air/fuel maps for that motor</TD></TR></TABLE>
PM6 = Good enough
PG7 = USDM D16A1, it's ok.
PM7 = The correct ecu, put hard to find.
A chipped PM6 with a PM7 map= the best.
Old Apr 10, 2007 | 08:26 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
A chipped PM6 with a PM7 map= the best.</TD></TR></TABLE>
Absolutely. And the vehicle will run just fine with a PM6, don't believe that your car will run like crap with it.
I say get the Rover VC that was offered to you, do something different .
tyler100
Apr 21, 2008 09:18 AM
crx18c1
10
Jun 15, 2007 11:37 AM
_Cyclone_
Jun 25, 2005 11:04 PM
spoon*honda
Oct 11, 2004 03:31 PM
HondaPartsHero
Nov 6, 2002 10:16 PM
