HELP b16 obdo in to 91 dx
Old Apr 4, 2007 | 11:27 AM
strokedb16delsol's Avatar
Default HELP b16 obdo in to 91 dx
i just put a complete b16 obdo swap in my 91 dx with all si wire harness for mpfi everything is working no check engine light. my problem is at 1000 rpm to 1500 it has a misfire but after 1500 it drives and revs fine and idles mint i changed all igniton stuff and checked all injectors everything is ok does any one have any ideas
Old Apr 4, 2007 | 11:34 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: HELP b16 obdo in to 91 dx (strokedb16delsol)
Make sure that the timing is dead on, then go from there. Is it smoking when it misfires?
Old Apr 4, 2007 | 11:38 AM
Default Re: HELP b16 obdo in to 91 dx (wiZCo)
timing is dead on no smoke runs super clean
Old Apr 4, 2007 | 01:20 PM
Bejita's Avatar
Are you running high octane fuel? fuel filter clogged? Did you adjust the idle speed screw properly?
big_daddy234
Dec 3, 2009 05:20 PM
808ef9
Sep 26, 2008 09:57 PM
WWTeg
Mar 9, 2008 05:00 PM
ek_slut
Jul 15, 2005 02:15 PM
