B18C1 Build Question
Old Apr 4, 2007 | 11:04 AM
tpdc2's Avatar
Default Skunk2 Stage 2s power range
Im building a mild B18c1 allmotor build.
ITR pistons
skunk2 stage 2s
mugen headgasket
supertech retainers and springs
smsp header
skunk2 i.m.
My question is I heard that skunk2 stage 2 cams make the most power from 8k and above. What Rpm's will the car be able to go up to with stock rods? Also would stock injectors/fuel pump be ok or will i have to upgrade? Thanks
Modified by tpdc2 at 3:01 PM 4/4/2007
Old Apr 4, 2007 | 01:12 PM
tpdc2's Avatar
Default Re: B18C1 Build Question (tpdc2)
bump
Old Apr 4, 2007 | 02:01 PM
tpdc2's Avatar
ttt
Old Apr 4, 2007 | 02:05 PM
all-mtr-teg's Avatar
I'm reving a similar build b18c1 to 9k rpm on stock rods, itr pistons, blox type b cams, s2 i.m. edelbrock header, yada yada yada yada.
Old Apr 4, 2007 | 02:46 PM
tpdc2's Avatar
Default Re: B18C1 Build Question (all-mtr-teg)
Cool. so it would be safe to push it to 8500-9000.
Old Apr 4, 2007 | 03:21 PM
tpdc2's Avatar
Anyone else use stock gsr rods and rev that high
Old Apr 4, 2007 | 04:01 PM
doood's Avatar
been there done that
if you want to try taking stock rods that high at least get arp bolts and install them properly
Old Apr 4, 2007 | 04:08 PM
tpdc2's Avatar
Default Re: B18C1 Build Question (doood)
do i have to make any modifications to the rods to do that
Old Apr 4, 2007 | 04:14 PM
Jay_Sensing's Avatar
Ditto, use the ARP rod bolts as doood said, 70 bucks worth of insurance even though a GSR would probably be fine. I would do it anyway because it's so cheap.
That being said, you will have to strap the car down to a dyno to see where it makes power to. S2 says that the cams make peak power at 9k but when I was experimenting with my car at the track two weekends ago, I netted the best ET by shifting at 8700, a full .2 quicker than 9k and my 60's are all within .05 of each other so it wasn't driver error. I would make 4 passes with each change to see how the car reacted.
Old Apr 4, 2007 | 04:19 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpdc2 &raquo;</TD></TR><TR><TD CLASS="quote">do i have to make any modifications to the rods to do that</TD></TR></TABLE>
the big end has to be resized. have a machine shop do it.
Old Apr 4, 2007 | 04:45 PM
tpdc2's Avatar
Ok thanks alot guys. I am getting the work done at whip factory a local shop hopefully they would know a good place to get this done at.
Old Apr 4, 2007 | 04:55 PM
abusedhusband's Avatar
Default Re: Skunk2 Stage 2s power range (tpdc2)
im not sure what you can rev to safely. but i would not recommend going past 9k on stock rods. as far as the injectors and pump you will be fine. just turn fuel pressure up a little, no more than 60 psi
Old Apr 4, 2007 | 10:12 PM
NUISANCE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
the big end has to be resized. have a machine shop do it.</TD></TR></TABLE>
Why would you need to do that when they are the same size as the stock bolts?
Old Apr 5, 2007 | 05:30 AM
tpdc2's Avatar
Default Re: B18C1 Build Question (NUISANCE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NUISANCE &raquo;</TD></TR><TR><TD CLASS="quote">
Why would you need to do that when they are the same size as the stock bolts?</TD></TR></TABLE>
so does anybody know for sure if i have to get the rods machined or not?
Old Apr 5, 2007 | 09:42 AM
NABeastRR's Avatar
no you dont, i think he is thinking of LS rods they have to be resized to fit the ITR pistons on there but GSR rods will go right on no problems
Old Apr 5, 2007 | 09:47 AM
tpdc2's Avatar
Default Re: B18C1 Build Question (NABeastRR)
what mm rod bolts bolt up to grs rods
Old Apr 5, 2007 | 10:17 AM
blk_hatch978's Avatar
Banned
if you wanna rev higher...get eagle rods..and you can put this all behind you!
Old Apr 5, 2007 | 11:03 AM
NUISANCE's Avatar
Eagle rods won't fit ITR pistons, plus the cheapest Eagle rods I found were $300.
Just get the ARP bolts, part check in the performance section. I picked mine up from there for less than $70 shipped.
Old Apr 5, 2007 | 11:29 AM
tpdc2's Avatar
Default Re: (NUISANCE)
thanks alot guys
Old Apr 5, 2007 | 12:18 PM
redGSRguy's Avatar
Default Re: (tpdc2)
I got my arp stuff from user BlueR, might want to shoot him a PM. Good guy !
Old Apr 5, 2007 | 12:30 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NUISANCE &raquo;</TD></TR><TR><TD CLASS="quote">Why would you need to do that when they are the same size as the stock bolts?</TD></TR></TABLE>
because pressing out the old one's and pressin the new ones distorts the journal. you have it honed back to spec.
Old Apr 5, 2007 | 02:57 PM
tpdc2's Avatar
so i would just get it honed back to spec at a machine shop?
Old Apr 5, 2007 | 04:32 PM
Yes, just makes them round again.
No one is confusing LS rods and ITR pistons, that's a whole different ball park. The act of forcing out the old studs, putting in the new ones, and then properly stretching them distorts the bore of the big end slightly so they just need to be rehoned to spec. Not a big deal or expensive.
FWIW, I got my ARP's from summit for like 30 bucks shipped and I think the machine shop charged me 50 for installing and rehoning.
Of course that was done at the same time as my block and head plus balancing so it may be a bit more when it's all your doing but still, it's not a bad price.
Old Apr 5, 2007 | 05:10 PM
tpdc2's Avatar
Default Re: B18C1 Build Question (Jay_Sensing)
Ok so do you think the will charge me alot extra to get this done? Or does it require any other work to be done? There are going to be in the block when they install the pistons.
Old Apr 7, 2007 | 09:11 AM
NUISANCE's Avatar
because pressing out the old one's and pressin the new ones distorts the journal. you have it honed back to spec.</TD></TR></TABLE>
True, I though it was meant that the holes for the bolts had to be opened. Sorry for the confusion.
SecretFWD
Apr 1, 2013 02:35 PM
bradabu
27
Mar 26, 2012 08:40 AM
Midori Green
12
Apr 9, 2008 08:12 AM
civicking99
10
Dec 24, 2007 06:18 PM
95 integra
Dec 9, 2003 03:08 PM
