how hard to add ac to 91 EF DX
Old Apr 4, 2007 | 10:31 AM
rexxb16's Avatar
Default how hard to add ac to 91 EF DX
How hard would it be to add AC to a 91 standar EF hatch back?
I might pick one out without ac and i live in az 99 deg right now?
anyone here done it
Old Apr 4, 2007 | 10:42 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: how hard to add ac to 91 EF DX (rexxb16)
It's not all that complicated *if* you have the right parts. You need all the lines, a compressor (w/ bracket), condenser, an A/C fan and a drier to start. Then you will have to install the evaporator under the dash in place of your bypass tube and install the wiring. Make sure you get all new o-rings, a new drier, and even maybe a new expansion valve (all these are still available from Honda). Then either fill the system yourself (there's a thread on here that gives pretty detailed instructions, just search 'air conditioning recharge'), or pay to have it done. I have an evaporator, wiring and fan if you'd like them (for a fee of course ).
I will actually be re-installing mine fairly soon as well, so maybe you'll catch my thread on the install. My costs will be around $350: $250 for all necessary components and $100 for an evacuation / fill. Good Luck!
Old Apr 4, 2007 | 11:55 AM
mra4886's Avatar
easy just roll the windows down.
j.k. but just like he stated ^^.
Old Apr 4, 2007 | 11:56 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: how hard to add ac to 91 EF DX (mra4886)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mra4886 &raquo;</TD></TR><TR><TD CLASS="quote">easy just roll the windows down.
j.k. but just like he stated ^^. </TD></TR></TABLE>
Hell yeah, I used to tell customers that they had 2x50 air conditioning at UHaul (lots of old trucks, lots of bad compressors = no A/C)....... 2 windows down x 50 mph = air conditioning
Old Apr 4, 2007 | 12:16 PM
mra4886's Avatar
Default Re: how hard to add ac to 91 EF DX (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">Hell yeah, I used to tell customers that they had 2x50 air conditioning at UHaul (lots of old trucks, lots of bad compressors = no A/C)....... 2 windows down x 50 mph = air conditioning </TD></TR></TABLE>
lmao. im use that 2x50=airconditioning. whenever someone asks me or complains cause i dont have ac. im be yes i do i got the 2x50 ac.
Old Apr 4, 2007 | 03:00 PM
rexxb16's Avatar
im gonna have to try to piece it together
Old Apr 4, 2007 | 03:12 PM
rayzian's Avatar
I survived one humid *** summer so far with the 2x50 ac, hopefully I'll survive this summer aswell...
Old Apr 4, 2007 | 05:07 PM
Alan Wil's Avatar
It shouldn't be too hard like wiZCo stated above... about 3-4 years ago converted from R12 to 134a... took ALL of the A/C components OUT, flushed, cleaned, re-furbed.
A/C system came out really EASY....
TIP: For those with a car several years old and the A/C isn't blowing as hard as it once did take out the evaporator core and CLEAN it.
Mine was full of hair and crap...
PS: If you R&R any component use R12 oil on the o-rings...
Oh, another thing, I went thru about 10 (steel) dryers thru Autozone/Advance Auto that were by 4 seasons.... ALL were crap, had rust inside of them... loose caps, no caps (which allows moisture in=very bad)
At about the 10th unit....
Went with a HONDA dryer... came in vacum packed see thru packaging, with CAPS on the dryer as well.... Inside was CLEAN... full aluminum, drop dead gorgeuos welds on it... and it was a couple of pennies cheap to boot...
Only downside on the Honda dryer No sight glass so you do the charge by the pressures...
Up side for those trying to save "weight" is the Honda Dryer is
Old Apr 5, 2007 | 12:02 AM
rexxb16's Avatar
Default Re: how hard to add ac to 91 EF DX (Alan Wil)
Will the crx ac system work on a 91 EF hatch? I think i located a system from crx just need to know if its going to fit
Old Apr 5, 2007 | 07:51 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexxb16 &raquo;</TD></TR><TR><TD CLASS="quote">Will the crx ac system work on a 91 EF hatch? I think i located a system from crx just need to know if its going to fit</TD></TR></TABLE>
Yes, it will work just fine.
Old Apr 5, 2007 | 02:27 PM
rexxb16's Avatar
even if the system is from an 89 will still work on a 91 hatch&gt;?
Old Apr 5, 2007 | 04:17 PM
sporkcrx's Avatar
I've been thinking about doing this as well, just hesitant about spending a few hundred bucks doing it.
Old Apr 5, 2007 | 05:00 PM
MRN1120's Avatar
Here is a write up from crxcommunity.com
http://crxcommunity.com/viewtopic.php?t=1279
Old Apr 6, 2007 | 09:11 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexxb16 &raquo;</TD></TR><TR><TD CLASS="quote">even if the system is from an 89 will still work on a 91 hatch&gt;?</TD></TR></TABLE>
Yes, all 88-91 Civics/CRXs share the same A/C package.
Old Apr 6, 2007 | 01:41 PM
dr_latino999's Avatar
Default Re: how hard to add ac to 91 EF DX (rayzian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rayzian &raquo;</TD></TR><TR><TD CLASS="quote">I survived one humid *** summer so far with the 2x50 ac, hopefully I'll survive this summer aswell...</TD></TR></TABLE> 3 years in Miami and CFL, you all are pansies
Old Apr 6, 2007 | 02:12 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: how hard to add ac to 91 EF DX (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> 3 years in Miami and CFL, you all are pansies </TD></TR></TABLE>
6 years in Midwest July and August is just as bad
Old Apr 6, 2007 | 02:50 PM
6 years in Midwest July and August is just as bad </TD></TR></TABLE> Ya, but I have April --&gt; October
harman_efsedan
19
Jan 19, 2018 03:00 AM
apm
Jun 24, 2016 03:08 PM
Leland
Jul 24, 2009 01:36 PM
93formula
Apr 22, 2005 09:47 PM
