Dash Lights - Speedo
Old Apr 4, 2007 | 06:49 AM
macphegf's Avatar
Default Dash Lights - Speedo
Hi, did a search, couldn't find anything on the speedo and rev counter lights all out. All other dash lights work but these don't. Only just bought the car ('99 coupe V6 UK car) and I'm sure they were all lighting up before. I assume it's multiple bulbs but the fuse (no.9 on the drivers side?) appears ok.
If it is a bulb, how easy is it to get at it/them. Any other ideas of what could cause it welcome!
Thanks.
Old Apr 4, 2007 | 06:56 AM
TheMuffinMan's Avatar
He knows where you live!
I'm not sure what your 99 looks like but my guess would be it's similar to our 98-02 accords?
If that's the Case I want to say there's just 4 screws holding it in and then you can pull it outwards
Old Apr 4, 2007 | 07:03 AM
macphegf's Avatar
Default Re: (TheMuffinMan)
I think the dash is basically the same as your 98-02 accords (only the 'proper' way around ). Do you know where the screws are located?
Old Apr 4, 2007 | 07:54 AM
I haven't actually done it myself, but I'd imagine there's two above it probably at an angle (need to lower steering wheel) and probably two below it
Old Apr 4, 2007 | 07:57 AM
macphegf's Avatar
ok, cheers, I'll give it a shot.
Old Apr 5, 2007 | 01:55 AM
macphegf's Avatar
Default Re: (macphegf)
There's 2 screws on the top alright but I can't find any underneath, didn't want to force it incase there were more screws i had missed, does anyone know for certain where the other screws are?
mooneybeams
Mar 17, 2007 08:37 AM
VTECtravler
13
Oct 4, 2006 07:51 AM
Lewy. Dee Ayy
Jan 25, 2006 10:34 AM
matt_in_sd
Nov 12, 2001 11:44 PM
