sir headlight question
Old Apr 4, 2007 | 06:25 AM
Integra99's Avatar
Default sir headlight question
I tried searching but the only things i found didnt answer the question, so im putting it up here. What are the 3 prongs on the back of the headlight which one is what. I am not sure since it didnt come with a plug.
Also I am looking for the sir jdm bumper filler piece for a friend if you have one let me know. https://honda-tech.com/zerothread?id=1941794
Old Apr 4, 2007 | 12:11 PM
Integra99's Avatar
Default Re: sir headlight question (Integra99)
Bump
Old Apr 4, 2007 | 12:25 PM
wiZCo's Avatar
Stouts 'n' Scotch
You have a picture of these three 'prongs'? Not sure what you mean.
Old Apr 4, 2007 | 12:29 PM
hybridzOr's Avatar
Default Re: sir headlight question (wiZCo)
h4h headlight plug, one common ground 2 12 volts(lo beam, hi beam)...
Old Apr 4, 2007 | 12:33 PM
Integra99's Avatar
Default Re: sir headlight question (hybridzOr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridzOr &raquo;</TD></TR><TR><TD CLASS="quote">h4h headlight plug, one common ground 2 12 volts(lo beam, hi beam)...</TD></TR></TABLE>
is there a certain prong for the lo beam, high beam, ground or does it not matter.
Old Apr 4, 2007 | 02:59 PM
Slurp56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra99 &raquo;</TD></TR><TR><TD CLASS="quote">
is there a certain prong for the lo beam, high beam, ground or does it not matter.</TD></TR></TABLE>
Yes it matters. Use a test light or a multi-meter to determine which wire is what by turning your headlight switch on and measuring at the plug.
Old Apr 4, 2007 | 03:05 PM
Crx Jimmy's Avatar
I dont remember off the top of my head just get 2 lengths of wire, crimp some spade terminals on the end, then connect to your battery, hook them up to the prongs on the back and see what happens you will figure out the high and low and ground, they are the same as a regular H4 so if you can find out what pins are what they are the same as a h4h. If I remember correctly the ground is on the left the center and right are for high/low. you will also have to wire in a relay. so the bulb doesnt have the low and high filament on at the same time, your bulb will burn out super fast this way.
for the relay
hook 85 up to the high beam power(spliced, power will still go to the high filament as well) . hook 86 to the ground. cut the low beam + wire and hook it to 30 , then hook 87a back into the low beam wire going to the light and leave 87 blank. when the high beam is switched on it will cut the circuit from 87a to 87 and thus turning the low beam off
sixfiveoh
Mar 16, 2007 12:07 AM
speed.freak
Mar 2, 2005 12:23 PM
WRTEG
Aug 9, 2004 04:44 AM
E-lude78
Jun 29, 2004 11:23 PM
I3ackfire
Mar 4, 2004 01:38 PM
