Civic CoilOvers on Accord Shocks...?
Old Apr 3, 2007 | 10:51 PM
hitvtecgetloud09's Avatar
Default Civic CoilOvers on Accord Shocks...?
well i have a set of civic coilovers laying around and i have a stock 95 ex as a daily driver...so i thought id give it a drop...would the civic springs fit on the accord shocks both front and back..
thanks
Old Apr 3, 2007 | 11:06 PM
SuShiBoiiii's Avatar
Default Re: Civic CoilOvers on Accord Shocks...? (hitvtecgetloud09)
dunno if it would fit but im pretty sure the ride quality would suck since the weight of an accord vs civic is totally different
Old Apr 3, 2007 | 11:09 PM
Default Re: Civic CoilOvers on Accord Shocks...? (SuShiBoiiii)
even if i had to buy some new coilovers for the accord they would be the 40 dollar ones off ebay..so i dont think there would be a difference...lol
Old Apr 4, 2007 | 06:24 AM
no one knows?
Old Apr 4, 2007 | 06:30 AM
hurleyint's Avatar
i know.
leave it stock.
Old Apr 4, 2007 | 09:31 AM
JDM_DC4_Fanatic's Avatar
Default Re: Civic CoilOvers on Accord Shocks...? (hurleyint)
if you MUST drop it, then get springs for your car. you will most likly either ruin the springs or the shocks with that.
Personally, I wouldent trust my life to some ebay crap cause i'm too cheap to buy real parts. Save up and get good components on your car.
Old Apr 4, 2007 | 10:18 AM
ECX's Avatar
ECX
* B A N N E D *
Default Re: Civic CoilOvers on Accord Shocks...? (JDM_DC4_Fanatic)
Suspension is the most important part of a car, no matter what kind of driving you do. (Not counting brakes.)
Do not cheap out on your suspension, you could die. Save up some money and get springs, and an alignment afterwords.
Old Apr 4, 2007 | 04:09 PM
Default Re: Civic CoilOvers on Accord Shocks...? (ECX)
i appreciate you guys teaching me how to go about "modifying" my car, but thats not wat i was looking for. i know some stuff on ebay are cheap and some are not. i choose not to care. as for the shocks on the car they are already blown not much worst can happen there. this car is just a DD i drive to work and school. so i thought it would be cool to give it a lil drop since i had the coilovers just sitting around...
im still looking for the answer to my original question..thanks
Old Apr 4, 2007 | 08:58 PM
lowered94accord's Avatar
first off..I highly doubt it..2nd off save your 40 bucks and change your oil or something..dont waste it on 40 dollar coilovers off ebay..you may think oh well it will do the drop and you may think your shocks are busted but just wait till you put those coilovers on it..you will be bouncing around all the time..which can cause suspension parts to bend(trust me it happened to me)..therefore you will have to spend hundreds of dollars getting new suspension parts..it will never ride good with ebay coilovers period! no matter what shocks you have...save up and buy some tein coilovers if you want some good ones or some ground control coilovers with koni yellows..might be expensive but its well worth the money!
Old Apr 4, 2007 | 09:13 PM
pos_cd5's Avatar
Default Re: Civic CoilOvers on Accord Shocks...? (lowered94accord)
find out the diameter of accord springs and compare it to your civic springs. chances are they will be the same and will fit. there, that answer your question
will it work is a different story, civics are alot lighter then accords, meaning lower spring rates. assuming the lowering springs arent half assed engineered and do feature higher rates to accomodate the drop, it should be similiar to your stock accord rates.
but then we run into the problem of near stock spring rates with a lowered ride height. which is almost like cutting your stock springs to being with and will cause problems such as bottoming out your suspension.
this is a bad idea that's only going to get worse. you have blown shcoks, which is a hazard already, and you want to throw on springs with questionable quality and wrong spring rates for your car.
whether you do it is up to you.
Old Apr 4, 2007 | 09:19 PM
Twixle's Avatar
ate my pixel
Default Re: Civic CoilOvers on Accord Shocks...? (pos_cd5)
He obviously doesn't care what happens to his car....if you want to lower your car for free, just heat up the springs until they compress to your desired ride height.
Disclosure: I am not responsible for your medical bills and/or damages caused to your car, nor other parties injured when your **** breaks because you did it the cheap way.
Old Apr 4, 2007 | 09:27 PM
pos_cd5's Avatar
Default Re: Civic CoilOvers on Accord Shocks...? (accord2021)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord2021 &raquo;</TD></TR><TR><TD CLASS="quote">He obviously doesn't care what happens to his car....if you want to lower your car for free, just heat up the springs until they compress to your desired ride height. </TD></TR></TABLE>
does that seriously work???? i've heard of drifters heating up and then cooling their stock rear springs to make them stiffer, but not to lower them.
Old Apr 4, 2007 | 09:30 PM
yea it works..ive seen people do it before..I didnt think it would work either..but you can take a blow torch or something to the shocks..and wham your car is lower..but will probably be uneven on all sides lol
Old Apr 4, 2007 | 09:32 PM
TheMuffinMan's Avatar
He knows where you live!
hahah never heard of that either
I imagine it's just heat the living crap outta them till they melt downwards
Old Apr 4, 2007 | 09:47 PM
pos_cd5's Avatar
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">hahah never heard of that either
I imagine it's just heat the living crap outta them till they melt downwards</TD></TR></TABLE>
sounds dangerous
yea pretty much haha not a very good idea..but if you have a beater you just drive into grocery carts...id do it lol
Old Apr 4, 2007 | 09:48 PM
Yeah, doesn't sound too safe to me, nor does driving around on blown suspension and using 40 dollar ebay parts, whatever
Old Apr 5, 2007 | 12:10 AM
philadd's Avatar
Lowering a car by heating springs with a torch or whatnot has been around for ages... But then companies started making aftermarket springs.
Old Apr 5, 2007 | 12:51 AM
pos_cd5's Avatar
Default Re: (philadd)
o wait, do you guys mean they heat it with the torch while the spring is still on the car? if so then it makes sense. i was thinking with the spring out.
Old Apr 5, 2007 | 12:54 AM
philadd's Avatar
Default Re: (pos_cd5)
Yes, while still installed on the car.
They don't melt or anything like that. It takes WAY more heat to do that... But the spring rates still get all screwed up.
Old Apr 5, 2007 | 03:35 PM
Bruce Banner's Avatar
in to c what happens to this car.
Old Apr 5, 2007 | 05:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, doesn't sound too safe to me, nor does driving around on blown suspension and using 40 dollar ebay parts, whatever</TD></TR></TABLE>
for the record...i got the springs for free and i had them on my civic for about a year and nothing happend to my car...now i know that the spring rate for a civic and accord are diff...but these being ebay univeral ones..i figure they should fit an accord....guess well never know till i try it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bruce Banner &raquo;</TD></TR><TR><TD CLASS="quote">in to c what happens to this car.</TD></TR></TABLE>
you'll just have to wait and see...
Old Apr 6, 2007 | 08:40 PM
Default Re: (hitvtecgetloud09)
I cant wait to see this guy running back to honda tech with suspension problems..civics are lighter therefore springs rates are different...so your accord is going to be putting a lot more weight on them which=suspension problems..plus they are from egay which means they are off-brand and are going to ride like ***
masijdm
Dec 14, 2008 06:19 PM
RedEyeZ18
Apr 14, 2007 09:58 PM
DrewQ1
Dec 16, 2003 07:18 PM
Sickster
Jul 15, 2003 05:46 PM
