Shopping list for JDM B18C Type R swap
Old Apr 3, 2007 | 09:42 PM
Kidnkorner's Avatar
Default Piecing A JDM B18C Type R swap together
I ordered the 2000 Motor, transmission, ECU package for $4500, not the complete changeover.
I am currently putting my shopping list together for the mentioned motor for my 1989 CRX Si. So far this is what I have. Please help me with missing parts and fill in the blanks if you wouldn't mind.
Timing belt
Water pump
Water pump gasket
Top end gasket kit
spark plug wires
NEW OBD1 Distributor (just for piece of mind)
Rywire OBD1 Computer and Plug and play wire harness
Hasport EFB2 Mount kit
Hasport Shift linkage
Hasport A/C Braket
Autozone 90-93 Axles and intermediate shaft
Spark plugs
Alternator belt from/for?
A/C belt From/for?
Throttle cable and bracket From/for?
Upper radiator hose From/for?
Lower radiator hose From/for?
Clutch cable From/for?
Fuel pump From/for?
Fuel filter
Modified by Lynx Bus Type R at 7:56 PM 4/4/2007
Old Apr 4, 2007 | 05:44 PM
Super Chicken's Avatar
Default Re: Piecing A JDM B18C Type R swap together (Lynx Bus Type R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lynx Bus Type R &raquo;</TD></TR><TR><TD CLASS="quote">I am currently putting my shopping list together for the mentioned motor for my 1989 CRX Si. So far this is what I have. Please help me with missing parts and fill in the blanks if you wouldn't mind.
Engine/Transmission
Timing belt
Water pump
Water pump gasket
Top end gasket kit
spark plug wires
Hasport A/C Braket
Spark plugs
Alternator belt from/for? I had to use one I found that fit at the parts store I can get the p/n if you need it
A/C belt From/for? The original if you use the original compressor
Throttle cable and bracket From/for? I made my bracket and used a Civic Si cable
Upper radiator hose From/for? I used the type R hoses and cut pieces of the original EF hose to use as a shim
Clutch cable From/for? 90-93 Integra
Fuel pump From/for? Stock
Fuel filter
Why would you change the axles from the TypeR? I have just finished puting in my Type R and the axles fit no problem (after removing the dust shield of course)
the only thing I would like to change is that I don't like the "shim" that I used to fit the radiator and I'm wanting to see if a type R radiator will fit in my EF's radiator hole
Old Apr 4, 2007 | 05:54 PM
Kidnkorner's Avatar
Default Re: Piecing A JDM B18C Type R swap together (Super Chicken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Chicken &raquo;</TD></TR><TR><TD CLASS="quote">
Why would you change the axles from the TypeR? </TD></TR></TABLE>
They are used.
I didnt order a complete changeover, just motor, transmission, and ecu.
By the way I once live in Maryville.
Modified by Lynx Bus Type R at 8:07 PM 4/4/2007
Old Apr 4, 2007 | 06:38 PM
I CRX I's Avatar
not to sure but you might need a 90-93 integra rear T bracket and b16 divers side mount bracket. correct me if im wrong
Old Apr 6, 2007 | 07:52 PM
Mr.Meowsome's Avatar
Default Re: (I CRX I)
lose the AC
Old Apr 6, 2007 | 07:59 PM
Max Kling's Avatar
You need the hydro to cable conversion arm also, and use the stock clutch cable.
You must have a nice bank account.
Old Apr 6, 2007 | 09:22 PM
Kidnkorner's Avatar
Default Re: (GodDamnStick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GodDamnStick &raquo;</TD></TR><TR><TD CLASS="quote">lose the AC</TD></TR></TABLE>
Sorry no can do, i live in phoenix. I'll be adding Power steering when I find a descent rack also. This will be my daily driver while I build up my K20R 93 coupe. Know anyone that will make Carbon fiber quarter panels?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max Kling &raquo;</TD></TR><TR><TD CLASS="quote">You need the hydro to cable conversion arm also, and use the stock clutch cable.</TD></TR></TABLE>
Sorry, its included in the EFB2 kit from HAsport.
Old Apr 6, 2007 | 10:35 PM
Default Re: (Lynx Bus Type R)
Sorry no can do, i live in phoenix. I'll be adding Power steering when I find a descent rack also. This will be my daily driver while I build up my K20R 93 coupe.</TD></TR></TABLE> well soooorry...we dont want the king to sweat in his dd type r ...anyway b18c5=a/c
Old Apr 7, 2007 | 01:04 AM
Kidnkorner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GodDamnStick &raquo;</TD></TR><TR><TD CLASS="quote"> well soooorry...we dont want the king to sweat in his dd type r ...anyway b18c5=a/c</TD></TR></TABLE>
lmmfgdao!!!!!!!!!!!!
Old Apr 7, 2007 | 05:33 AM
D Rex's Avatar
What about Vss? 2000 is electronic and EF is cable. Cluster swap?
Old Apr 8, 2007 | 09:37 PM
Kidnkorner's Avatar
Default Re: (D Rex)
if I can find one i'd like to get a EDM cluster
Old Sep 26, 2008 | 08:30 PM
jdmek9imagex's Avatar
Default Re: (D Rex)
get a 90-93 integra VSS, it is cable
Old Sep 26, 2008 | 10:33 PM
CRX_RR's Avatar
Default Re: Piecing A JDM B18C Type R swap together (Kidnkorner)
be nice to have a UK cluster reads 150
crxpwr1
Jul 17, 2006 10:11 PM
LazJDM
Apr 17, 2006 05:00 PM
ef9robert
17
Feb 24, 2006 05:52 AM
nichols
10
Feb 15, 2003 09:44 AM
KevronsEG
10
Feb 11, 2002 12:54 PM
