205/55-14 nitto drag radials good for 225whp+?
Old Apr 3, 2007 | 08:38 PM
wfocrx's Avatar
Default 205/55-14 nitto drag radials good for 225whp+?
I have a 2050lb crx with a turbo d16 that make 225whp. I am going to eventually have about 300whp when I put my new motor in. I was wondering if 205/55-14 nittor drag radials would hook up pretty good at these power levels at the track. Also, do they hook ok on the street at normal tire pressure? I don't street race; but, will probably have them on my car all the time since I only drive about 500mi a month and sometimes like to play around a little from a roll and my current 205/40-16s just spin when punched from a roll.
Old Apr 7, 2007 | 03:52 PM
wfocrx's Avatar
anybody run these?
Old Apr 7, 2007 | 04:08 PM
RaceProfessor's Avatar
Default Re: (wfocrx)
They'll hook decent for 225whp. BFG's would be better but the Nitto's seem to last longer. At regular tire pressures (30+psi) and cold, they are marginally better than street tires but not much.
Old Apr 7, 2007 | 04:11 PM
wfocrx's Avatar
cool thanks. Will 225/50-15 bfgs be good for upto ~300whp? should I just get those instead?
Old Apr 7, 2007 | 04:22 PM
Yes, you should get the 225's instead. Their tread life is limited but they work better and they don't cost much more than the Nitto's.
Old Apr 7, 2007 | 04:57 PM
wfocrx's Avatar
will the 225/50-15s fit alright on a crx? what offset? I was thinking of getting some 15x6.5 rota slipstreams w/ the 38/40mm offset.
JDM_EJ8
Oct 23, 2012 03:39 PM
accord99power
May 27, 2009 03:17 PM
jugodmyko
Oct 19, 2006 09:52 AM
Dragline
Nov 29, 2005 08:21 PM
tygsr
Oct 20, 2002 07:32 AM
