Swapping a D15B Japan motor into a 91 civic...NEED HELP
Old Apr 3, 2007 | 07:20 PM
bluehondasi2000's Avatar
Default Swapping a D15B Japan motor into a 91 civic...NEED HELP
I have a 1991 civic, and i bought a 92-95 d15b japan motor, I am doing the swap and hasport is converting all of the harness over to work with a obd1 computer for a 1.6 vtec. Is it hard to convert the car over to a hydraulic transmission? and i also have another major problem, is getting the motor to mount in, I am trying to find motor mounts but i am unable to find then for a d series engine, i have found them only for a b series, will they work the same? if anyone can help me out that would be great thanks.
Old Apr 3, 2007 | 07:37 PM
BlueCrxNC's Avatar
Just reuse your cable transmission. You won't find D-series Hydro mounts right now and no B-series won't work. Keeping cable you'll reuse all of your mounts, including the driverside that mounts to the block.
Old Apr 3, 2007 | 07:53 PM
sohcvtec91hatch's Avatar
Default Re: (BlueCrxNC)
EFstyle
May 18, 2011 03:18 PM
blaak-crx
Apr 23, 2008 09:02 PM
NSfit
Sep 15, 2006 10:37 AM
4drDA
Sep 3, 2005 02:55 PM
BACKintheDA
Mar 19, 2004 06:30 AM
