Power loss running way too rich
Old Apr 3, 2007 | 07:19 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default Power loss running way too rich
alrite well i wasnt sure if i should post this because i dont think anyone can help me at this point, after hours of searching and troubleshooting i am sick to my stomach and beg of your help. no to start of i will explain how it all went down. one night i decide to take my car on the highway and do some pulls, well i only got to do one, i launched my car and it hauld *** and i mean it really pulled hard. well i got too 5th gear at about 120-125 and the car lost power real bad and didnt wanna pull thru the rpms. at first i didnt think much till i tried to fix it, well i thru a wideband o2 on it and guess what, 12.5 at cruise and 10.9-11.5 at WOT. now this is a list of what i have and what is new. at first before the wideband i swore it was lean, which was true because a had a faulty o2, now with no o2 and the wideband it goes dumb rich.
91 civic dx
95 h22a 250 compression all across
CTR trans
rywire obd-0 to obd1
no check engine lights
walbro 255
48psi
new parts,
fuel pump
regulator
rail
injectors
ecu
dizzy
cap
rotor
wires
plugs
map
tps
iat
iacv
throttle body
and anything else that bolts on the engine, and i have no cat, no muffler so there is no clog, and stock motor stock ecu any help ppppplllleeeaassseee
Modified by H22EHSI at 10:44 PM 4/4/2007
Old Apr 4, 2007 | 01:19 PM
Default Re: Power loss running way too rich (H22EHSI)
someone please help me
Old Apr 4, 2007 | 01:54 PM
EF2_Sedan88's Avatar
east coast junk yard its ur best bet nick????
Old Apr 4, 2007 | 01:58 PM
high_revs's Avatar
faulty ecu????
Old Apr 4, 2007 | 02:10 PM
Default Re: (h2b_eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">faulty ecu????</TD></TR></TABLE>
check the top and there is a list of parts i replaced, not to mention i tried all the parts i replaced on a friends car and they worked flawless
Old Apr 4, 2007 | 05:46 PM
Default Re: (H22EHSI)
please help
Old Apr 4, 2007 | 05:58 PM
88ED8's Avatar
I'm no expert when it comes to diagnostics, but if I were you I'd check your compression, do a leak down, check spark plug gap, check fuel filters (even the ones in the injectors), and maybe tune it with the use of a wideban on a dyno... Just some thoughts.
Old Apr 4, 2007 | 06:44 PM
Default Re: (88ED8)
iight but like i posted on the top i did all that.....compression is 250 all across!!!
Old Apr 4, 2007 | 07:06 PM
ttt
Old Apr 5, 2007 | 02:26 AM
88ED8's Avatar
ttt try checking your continuing transfuncktioner
Old Apr 5, 2007 | 10:17 AM
9WON4's Avatar
Default Re: (88ED8)
that's what you get for putting a prelude motor in a crx .......j/k bump good luck
Old Apr 5, 2007 | 10:32 AM
sauceja's Avatar
Default Re: (9WON4)
you said somewhere else you were using a stock p13. If that is the case and you jumped up your rail psi to 48 then that would explain your low afr's on a stock motor with stock ecu.
You didn't throw a cel when you pulled the stocker O2 sensor for the wideband? That would cause limp and rich conditions as well.
GL
Old Apr 5, 2007 | 10:33 AM
UltimX's Avatar
Default Re: (9WON4)
are these parts brand new or new as in from a different car? I would suspect your injectors might be stuck open. But if they are brand new then i don't know. And wheres your o2 sensor?
Old Apr 5, 2007 | 12:46 PM
Default Re: (UltimX)
iight well i fixed the problem and now i wanna race
Old Apr 5, 2007 | 12:51 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22EHSI &raquo;</TD></TR><TR><TD CLASS="quote">iight well i fixed the problem and now i wanna race </TD></TR></TABLE>
lets meet up one of thes weekends
Old Apr 5, 2007 | 12:54 PM
sanimalp's Avatar
$cat /dev/urandom
what was the problem?
Old Apr 5, 2007 | 12:58 PM
high_revs's Avatar
flex pipe caused a clog in the exhaust system..that what happens when a car is fast
Old Apr 5, 2007 | 01:19 PM
UltimX's Avatar
pics? was it the flex pipe breaking down that cause the clog?
Old Apr 5, 2007 | 01:20 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">pics? was it the flex pipe breaking down that cause the clog?</TD></TR></TABLE>
yes, from what he explained in another thread thats what happened...it must of been under a lot of stress, and prob real old.
Old Apr 5, 2007 | 07:04 PM
haha really old try three months. the car is just such a beast im gonna go to the garage and get it
Old Apr 5, 2007 | 07:25 PM
this is what made me miserable and change all those parts on the top for absolutley nothing
Old Apr 5, 2007 | 09:34 PM
UltimX's Avatar
atleast u know ur ***** reliable and u don't have to worry about it. Thats weird, i never seen one like that in my life. I wonder how that happened? and its good u found the problem.
Old Apr 5, 2007 | 10:27 PM
sanimalp's Avatar
$cat /dev/urandom
whoa.. thats freakin crazy. there is some backpressure for you..
Old Apr 6, 2007 | 05:12 PM
high_revs's Avatar
damn 1st time i saw something like that....what made you look at that? lol
Old Apr 6, 2007 | 08:15 PM
heard a slight leak, decided to fix it and what do you knoe
