ZC trannys use different axles?
Old Apr 3, 2007 | 06:44 PM
hondacivic90zc's Avatar
Default ZC trannys use different axles?
i am going to purchase the SOHC ZC witht the ZC tranny and i have been told that with my 88 crx dx i will need new axles, is this true? if so which ones?
the car is already converted to mpfi so is there anything else i will need to do this swap because from my understanding it is pretty straight forward.
thanks for the help
Old Apr 3, 2007 | 10:04 PM
IP RACING's Avatar
Default Re: ZC trannys use different axles? (iandavis90)
I have a sohc zc with zc tranny. if you want to spend less money just use your original dx tranny and axles they will bolt up to the zc block. because if you get the zzc tranny you will need da axles.which I think they are from like 87 integras. whatever you do dont try using your old axles with your new tranny. hope that helped
Old Apr 4, 2007 | 09:52 AM
Default Re: ZC trannys use different axles? (IP RACING)
the tech from HMOTORSONLINE where i was planning on buying from said that i need 90-93 integra half shafts?
Old Apr 4, 2007 | 10:12 AM
Mr.Death's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iandavis90 &raquo;</TD></TR><TR><TD CLASS="quote">the tech from HMOTORSONLINE where i was planning on buying from said that i need 90-93 integra half shafts?</TD></TR></TABLE>
You need 90-91 teg shafts or 1st gen B16 shafts(same)AND a ZC intermediate shaft. 90-93 intermediate shaft will not work, I know for sure cause I've tried.
Old Apr 4, 2007 | 09:52 PM
Default Re: ZC trannys use different axles? (Mr.Death)
would autozone or kragen sell the intermediate shaft i need or would i have to go to a junkyard or maybe ebay?
is the zc intermediate shaft the only one i could use and what is the full list of options for axles with the zc tranny?
Modified by iandavis90 at 2:46 PM 4/5/2007
Old Apr 8, 2007 | 07:10 AM
james29's Avatar
is it the same with a dohc zc tranny or is it the same tranny
Old Apr 8, 2007 | 07:54 AM
Super Chicken's Avatar
If you have the SOHC ZC engine & tranny with intermediate shaft you need the 90-93 Integra axles they will fall right in as long as you remove the metal dust seals from the spindles
I just did this yesterday so I know it works
repingjdm
Jul 25, 2010 08:06 PM
pandarex
13
Dec 12, 2006 11:13 PM
TH33G4MON3
10
Sep 11, 2005 02:30 PM
Sherm
Jan 12, 2004 06:16 PM
Aphrodavid
Nov 6, 2002 08:34 PM
