Question about valves?
Old Apr 3, 2007 | 06:43 PM
tpdc2's Avatar
Default Question about valves?
I am doing a mild all motor b18c1 build. I am getting itr pistons, skunk2 stage 2s, supertech springs and retainers, mugen headgasket, skunk2 i.m., aem short ram, smsp header, and skunk2 exhaust. My question is it important to upgrade valves? If so what kind?
Old Apr 3, 2007 | 07:10 PM
doood's Avatar
been there done that
Default Re: Question about valves? (tpdc2)
itr intake valves and stock exhaust valves. no need to get super expensive valves.
Old Apr 3, 2007 | 07:19 PM
tpdc2's Avatar
Default Re: Question about valves? (doood)
how much would those run me and where can i get em
Old Apr 3, 2007 | 07:52 PM
RPRacing's Avatar
Well, first of all ITR exhaust valves are the same as any other B vtec exhaust valve.
I do suggest you use flat faced valves from many of the different manufacturers out there. Use these to raise your compression, not a mugen headgasket. I suggest this because you can go to Honda any day of the week and be able to overnight (if its not in stock) a stock headgasket. You have to hope a mugen one is in stock somewhere in the US. besides that, your Piston-valve is less with a thinner head gasket. Use the valves to safely raise your compression.
Let me know if you need to order some, i sell many brands of valves
Old Apr 3, 2007 | 08:26 PM
dbiker207's Avatar
the stock valves will be fine u dont need to upgrade unless u plan on spray or somthing
Old Apr 4, 2007 | 04:02 AM
tpdc2's Avatar
Default Re: Question about valves? (dbiker207)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dbiker207 &raquo;</TD></TR><TR><TD CLASS="quote">the stock valves will be fine u dont need to upgrade unless u plan on spray or somthing</TD></TR></TABLE>
I saw a thread on here saying you shouldnt use stock valves, you have a chance of cracking a valve.
Old Apr 4, 2007 | 04:09 AM
RPRacing's Avatar
many many many people use stock valves and make a lot of power. i made 230 all motor on stock valves. there isnt anything wrong with using them, but i think in your application, get your compression up.
Old Apr 4, 2007 | 04:51 AM
dbiker207's Avatar
Default Re: (RPRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing &raquo;</TD></TR><TR><TD CLASS="quote">many many many people use stock valves and make a lot of power. i made 230 all motor on stock valves. there isnt anything wrong with using them, but i think in your application, get your compression up. </TD></TR></TABLE>
Old Apr 4, 2007 | 06:06 AM
tpdc2's Avatar
Default Re: (dbiker207)
The only reason right now I am considering valves is because I dont want a valve to crack off and mess up my motor. Just wanted to see what everybody else is running. I can come up with the money if I need them but I rather not just because of the finacial postition I am in right now. Would it be smart to go with supertech since i have their springs and retainers?
Old Apr 4, 2007 | 06:49 AM
dbiker207's Avatar
Default Re: (tpdc2)
dude the 2 of us answered your question, yes your stock valves are absolutly fine
Old Apr 4, 2007 | 07:23 AM
tpdc2's Avatar
alright thanks
Old Apr 4, 2007 | 11:21 AM
DonF's Avatar
Default Re: (tpdc2)
How old are your valves? Have they been mis-used? Are you going to blame Supertech or Skunk is one of your used valves fail?
Old Apr 4, 2007 | 12:16 PM
tpdc2's Avatar
Default Re: (DonF)
im not goin to blame them i just invested alot of my money in my motor and i want to take all procautions to make my motor as reliable as possible and not break anything and i have 83k on the valves.
Old Apr 4, 2007 | 12:37 PM
DonF's Avatar
Default Re: (tpdc2)
At 83K I would replace the valves, and have piece of mind.
Old Apr 4, 2007 | 12:42 PM
Combustion Contraption's Avatar
And pray the exh. guides in partiular havent worn enough to be a prob.
Old Apr 4, 2007 | 12:56 PM
tpdc2's Avatar
Default Re: (Combustion Contraption)
would you reccomend oem or aftermarket?
Old Apr 4, 2007 | 01:26 PM
Spoonie09's Avatar
Good set of valves $200-400
Blown motor " Because you dropped a valve and grenaded your piston" $750+
Old Apr 4, 2007 | 01:44 PM
tpdc2's Avatar
Default Re: Question about valves? (Spoonie09)
thanks alot. so supertech is a good choice for valves?
Old Apr 4, 2007 | 01:58 PM
DonF's Avatar
Default Re: (tpdc2)
Skunk2 or Supertech to keep consistant. Flat face and skip the mugen head gsk.
Old Apr 4, 2007 | 02:00 PM
tpdc2's Avatar
Default Re: (DonF)
y do you say skip the mugen headgasket
Old Apr 4, 2007 | 02:15 PM
Because he's smarter than you.
And the minute gain you get in compression wont outweigh the superior sealing properties of a 3 layer OEM gasket on this particular app.
Old Apr 4, 2007 | 02:33 PM
DonF's Avatar
I would rather increase compression by the valves than headgasket. Plus you need to surface the head ot make sure it is flat before you put it together.
Old Apr 4, 2007 | 02:45 PM
tpdc2's Avatar
Default Re: (DonF)
so the mugen headgasket is no good
Old Apr 4, 2007 | 03:27 PM
alterdcreations's Avatar
Default Re: (tpdc2)
if your surfaces are flat then it shouldn't pose any problem
Old Apr 4, 2007 | 03:31 PM
DonF's Avatar
Default Re: (tpdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpdc2 &raquo;</TD></TR><TR><TD CLASS="quote">so the mugen headgasket is no good</TD></TR></TABLE> No, just not necessary if you raise your compression by other ways. IE valve's and the standard ( by rebuilders that offer a warranty) surface clean of the head.
