Dual exhaust a 4 cylinder??
I like the way dual exhaust looks on your car and until about a day ago I thought it improves performance too. Someone told me that you shouldn't put dual exhaust on a 4 cylinder car b/c it actully slows it down. They told me it slows your 0-60 down by a whole second, is that true? I have a rex w/ a b18 dropped into it and I wanted to know if putting 2 seperate exhausts (not a dual tip) will actually slow me down.. please respond ASAP. Thanks guys..
LegallyBrown786 is right - it will not help you. there just isnt the same amount of exhaust present as there is for a 6/8 cly with larger displacement. if there isnt enough velocity, the exhaust will not flow as smooth. there is no reason for a dual exhaust in your situation
Guest
Posts: n/a
no exhaust velocity is a direct relation of piping diameter. you can have an effective dual exhaust if you use smaller diameter piping. if you have 2.5" for single exhaust for all header runners you would need aprox 1.25" diameter piping for each grouping of 2.
exhaust flow is created by a vacume effect. ive explained this in mroe detail in numerouse posts. do a search.
if you have proper diameter piping you will have no reduced performance.
backpressure is bad, exhaust flow is good.
too big of piping = not enough flow (balanced pressures)
i hate these backpressure homos who think backpressure is neccisary. it is NOT. its all physics
i would assume that the cross area of the exhaust pipe would determine the exhaust velocity, wouldn't the dual exhaust diamete need to be 1.58"?
sil04ver
Honda Civic (2001 - 2005)
Nov 16, 2007 05:13 PM
