FS: Exedy Stage 2 Cerametallic clutch and pressure plate SOHC Turbo
SOLD
I have a VERY gently used Exedy Stage 2 Cerametallic Clutch Kit that was used on my '90 Civic SI for just about 100 miles.
Clamp Load (Lbs) 1455
Disc Outer Diameter 212
Spline Teeth 20T
<clutch disc, pressure plate, BRAND NEW throwout bearing (for cable transmissions), alignment tool (if needed), NO pilot bearing (unless if you want a used one)>
The clutch was used on a freshly resurfaced OEM flywheel and held with ARP pressure plate bolts, so there is no need to worry about strange or uneven wear. I have been parting out my entire turbo kit, so I don't need this serious of a setup anymore. I have replaced it with an OEM style Exedy clutch kit (which is where the new throwout bearing came from).
This clutch kit will work on '89-'00 D-series Civics. For '89, you will need to change to '90-'00 style flywheel. For '92-'00, you will need to buy a different throwout bearing for use with hydraulic operated transmissions.
PM me if you have any questions
SOLD
Modified by DelSolDon at 5:29 PM 6/4/2007
Spline Teeth 20T
SOLD
HP goal was around 300HP, this clutch and pressure plate would've handled that no problem.
i was leaning towards an act xtss -- but i've always loved my exedy clutches.
if i can sell my headlights, i'mma pick these up
sounds good. if i didn't just pick up a set of Denji's i would consider partial trade for the lights. just let me know
get this quality clutch at the same price as a garbage XTD, F1, etc. clutch.
