need ''HELP'' on my B16 only running 3 cylinders
Old Apr 3, 2007 | 05:56 PM
EF88Vtec's Avatar
Default need ''HELP'' on my B16 only running 3 cylinders
hey can anyone help me. i have crx with a JDM B16 and i'ts only running 3 cylinders can you help me get my CRX to run good. its the #2 cylinder that is F#@$% up and ist geting spark and all i have changed the spark plugs and wires and fuel filter so if anyone can help. thanks
Old Apr 3, 2007 | 07:51 PM
1.6civicturbo's Avatar
Default Re: need ''HELP'' on my B16 only running 3 cylinders (EF88Vtec)
check the injector to see if your getting fuel. and do a compresion test on that cylinder
Old Apr 3, 2007 | 09:20 PM
Slurp56's Avatar
If you're not getting spark and you've replaced the plug and wire, I'd say your next step would be distributor cap, probably rotor too.
Old Apr 5, 2007 | 05:21 PM
EF88Vtec's Avatar
Default Re: need ''HELP'' on my B16 only running 3 cylinders (Slurp56)
hey thanks for the info.. im geting spark in all the cylinders im looking for some OBD 0 injectors hope that's my problem
Old Apr 5, 2007 | 06:15 PM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF88Vtec &raquo;</TD></TR><TR><TD CLASS="quote">hey thanks for the info.. im geting spark in all the cylinders im looking for some OBD 0 injectors hope that's my problem </TD></TR></TABLE>
is your injector firing?
Old Apr 5, 2007 | 07:53 PM
ALLMOTOR CRX's Avatar
probably a cloged injector.... change it hopefully thats your problem...
Old Apr 6, 2007 | 05:25 PM
EF88Vtec's Avatar
Default Re: (ALLMOTOR CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTOR CRX &raquo;</TD></TR><TR><TD CLASS="quote">probably a cloged injector.... change it hopefully thats your problem...</TD></TR></TABLE>
thanks i'll do that.
Old Apr 6, 2007 | 05:45 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: (EF88Vtec)
do a compression test on all 4 cylinders. if #2 is lower than the rest, well that sucks. cylinder leakdown tests are better, but compression is easier to do
Old Apr 8, 2007 | 10:42 AM
ALLMOTORCRX20's Avatar
Default Re: (ILcrxsi1)
Compression test your engine
If the compression is low on cylinder 2 then i feel bad for you
If its good, then your in luck all you have to do is check everything else in that cylinder
(injector, spark plug, ignition wire, distributor cap, injector clip and wire)
Old Apr 8, 2007 | 11:49 AM
chevelle's Avatar
Take a long screw driver or something similar. touch the tip of it to the injector and put your ear up to the end of it and listen to see if you hear the injector firing. Do that on all of them so you know what it's supposed to sound like.
Infact you can also unplug each injector while the engine is running and see what happens. If that injector doesn't bog the engine as much as the rest when you unplug it, you know that's your problem.
Modified by chevelle at 6:54 PM 4/8/2007
Stray9010
Sep 20, 2007 05:11 PM
hondakevin21
10
May 26, 2006 05:44 PM
hondakevin21
May 26, 2006 05:51 AM
craiger
May 22, 2005 09:28 AM
b16hatch
Feb 19, 2003 05:47 AM
