Need some help....5 lug set up on EK. Which booster prop. valve?
I have a 5 lug on my non running project car. Here is the issue. I have the following parts....
01 ITR booster, master cylinder and prop. valve
00 Civic SI Booster, master cylinder and prop valve
Which ones will work the best together? I know the Type R stuff is for ABS brakes, but has anyone used these parts on an EK with a good result? Also I have both proportioning valves in my tool box and don't know which one is which. Does any one have the part number off of one of these???? I know they have a number stamped on them.
Thanks
Thanks
Well, the ITR master and booster is interchangeable with your EK. So use that. As for the prop valve, if both fit, either one is fine.
Rising Sun
Mar 31, 2003 06:01 PM
S2K2S
Aug 13, 2002 09:00 AM
