Del sol rear disk swap
Has anyone done a rear drum to disk swap on a del sol? I installed the rear trailing arm, calipers, rotors and prop valve. The ebrake cables are off of the integra gsr, but they are too long and the heads are different. I went to a junkyard and looked at the cables off of a civic and they have the same heads as a GSR? What cables should I use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdgencrx »</TD></TR><TR><TD CLASS="quote">i made the gsr lines work</TD></TR></TABLE>
Did you put little washers or nuts in to take up the slack on the cable? lol
I know you had to loop the cables around the gas tank straps or the trailing arm but how did u keep the cable from sliding in the bracket under the cab right above the exhaust? Did you clamp it then attach to the underbody or what? Please share.
424racer
15
Apr 25, 2010 07:48 PM
delslo93
11
Jun 23, 2006 04:10 AM
275Performance
Feb 8, 2004 06:56 AM
