HELP ASAP.....CEL JUMP CLIP NOWHERE to be found.....
ok here the deal, my buddie and i did a mini-me swap in a CX...that already had a d15b7 in it.....so after everything is done..... car is misfireing and CEL is on.
Go to jump the 2 pin connector the 3wire connector isnt there eather....NOWHERE to be found..... Ripped out the glove box looked every where.....
two questions....
1) could it be anywhere else in the car??
2) what does the 2 pin connector do?
does it ground, does it add power
is it possible to jump the wire on the ecu directly....and if so what wire? do i ground it or jump it to anoter wire fromt he ecu? need help asap...need to figure the code..so i can DIAG the car...
two questions....
BlueShadow
Jun 1, 2005 10:08 PM
fishnfst
11
Nov 22, 2004 08:09 PM
