Throttle body problems
Old Apr 3, 2007 | 01:23 PM
Cpt Ben's Avatar
Default Throttle body problems
First off, i have a golden eagle intake manifold, and skunk2 throttle body. I recently changed the throttle body back to oem because of problems with the S2 unit.
But when i put the stock one on I cant seem to adjust the cable properly. When i adjust it so that the plate is closed at 0% throttle, I can only get 55% open with pedal to the floor. If i adjust it so that it opens all the way, ill be sitting at 30% throttle without pushing the pedal. Any help would be appreciated. Do i need a different TB?
Old Apr 3, 2007 | 03:04 PM
RACEPAK's Avatar
Default Re: Throttle body problems (Cpt Ben)
have you switched the tps between the throttle bodys?
if you did. did you adjusted the tps after the switch?
Old Apr 3, 2007 | 03:39 PM
allnaturalb16's Avatar
Default Re: Throttle body problems (RACEPAK)
your TB does not need to open to be exactly horizontal if thats what you are saying
Old Apr 3, 2007 | 10:33 PM
Cpt Ben's Avatar
Well i can tell that its not all the way open, as i can open it further by hand by just turning the throttle plate. And i used the tps that came with this throttle body, which to my knowledge was already adjusted.
Old Apr 4, 2007 | 03:19 PM
Default Re: (Cpt Ben)
what problems were you having with the S2?
Old Apr 5, 2007 | 05:18 PM
integratee's Avatar
Default Re: (allnaturalb16)
there are 2 adjustment scres ona throttle body. 1) is at the top it should be a flat head screw 2) is twoards the bottom, you cant see it, and it takes a alan key and 8mm i think. check it out. good luck
Old Apr 5, 2007 | 07:18 PM
Cpt Ben's Avatar
the s2 tb was sticky either stuck open, or stuck closed. I know how to adjust the cable, i dont think thats the problem.
Muckman
Oct 1, 2010 08:28 PM
monkalotamus
Nov 15, 2006 06:31 PM
FATninja19
Jun 26, 2006 10:51 PM
