Suspension & Brakes Theory, alignment, spring rates....
Question about bumpstops
Old Apr 3, 2007 | 10:55 AM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Community Influencer
Default Question about bumpstops
I just received my suspension today I have the Koni Yellow/GC setup with extended top hats, isolators, and bumpstops. GC said that they would assemble them but when I received the setup they were not assembled What I found though was 4 bumpstops but only two where cut. Should all 4 not be cut? Should they even been cut in the fist place? I know cutting them provides more room to lower the car more without bottoming out but what's the deal? I wonder why they only cut 2 and not all 4?
Any ideas?
Old Apr 3, 2007 | 10:59 AM
slammed_93_hatch's Avatar
Default Re: Question about bumpstops (CAN97SH)
the cut two are probably supposed to go up front. the longer in the rear.
Old Apr 3, 2007 | 11:07 AM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Default Re: Question about bumpstops (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">the cut two are probably supposed to go up front. the longer in the rear.</TD></TR></TABLE>
Any reason why? It's a 97 Prelude SH btw. I guess cause the front is heavier?
Old Apr 3, 2007 | 12:13 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CAN97SH &raquo;</TD></TR><TR><TD CLASS="quote">
Any reason why?</TD></TR></TABLE>
It just depends on how Honda designed the suspension. I don't know about preludes, but I can tell you that Civics & Integras have much more compression travel in the rear than the front w/ the stock setup. When lowering those cars, you really only need to worry about adding travel to the front (unless you have ridiculously soft rear springs).
Old Apr 3, 2007 | 12:22 PM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Default Re: Question about bumpstops (94eg!)
Well my spring rates are 400F and 450R. I'll stick them on the front as that makes sense. The front is heavier than the rear.
I just cant believe they didn't assemble everything when they said they were going to
99hondacura
Suspension & Brakes
11
Jul 7, 2008 09:13 PM
ITR32
Mar 2, 2007 06:11 PM
.I.Need.Money.
Suspension & Brakes
31
Feb 1, 2007 09:24 PM
bibong
14
Jan 31, 2007 08:18 AM
yellowturbo
Suspension & Brakes
28
Mar 31, 2006 05:27 AM
