Design for Sway bar Braces
Old Apr 3, 2007 | 09:44 AM
EG-Honda's Avatar
Default Design for Sway bar Braces
Someone asked, so for you DIY's here, I like this design because it adds more area to clamp the subframe with.
The design is for 6061 aluminum.
If you dont have the ability to make them, you can get them here...
https://honda-tech.com/zerothread?id=1940931
Old Apr 3, 2007 | 09:46 AM
highrev1987's Avatar
Default Re: Design for Sway bar Braces (EG-Honda)
solid works FTW!! EG-honda? did you used to be E-Honda
Old Apr 3, 2007 | 09:54 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Design for Sway bar Braces (highrev1987)
I would add a fillet to those 90* high stress areas. Besides that, the design looks pretty good...
Old Apr 3, 2007 | 11:16 AM
EG-Honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 &raquo;</TD></TR><TR><TD CLASS="quote">solid works FTW!! EG-honda? did you used to be E-Honda</TD></TR></TABLE>
No, but I do use E-Honda from Street Fighter for my avatar.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">I would add a fillet to those 90* high stress areas. Besides that, the design looks pretty good...
not a bad idea, but in the stress testing it only affected very high loads.
Old Apr 3, 2007 | 05:00 PM
EG-Honda's Avatar
I thought there would be more intrest in DIY info on the forum.
hmm
Old Apr 3, 2007 | 05:56 PM
EG2Driver's Avatar
maybe i missed some information, but you claim that this can be used instead of a ASR subframe brace?
Old Apr 3, 2007 | 05:59 PM
Felliph3's Avatar
Youre thinking of E.HONDA
Old Apr 4, 2007 | 07:05 AM
EG-Honda's Avatar
Default Re: Design for Sway bar Braces (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">maybe i missed some information, but you claim that this can be used instead of a ASR subframe brace?</TD></TR></TABLE>
That is not my intention at all, I was more looking at the other types of kits out there (beaks, bsq) and thought there could be a little more "meat" around the subframe for support. The ASR works by supporting at not only the swaybar mounts, but also the LCA bolts also, which makes it also act as a lower tie bar. The only reason I felt for a new design , was the apparent space that could be utilized for additonal support.
Old Apr 4, 2007 | 09:21 AM
philosofy1's Avatar
looks exactly like the beaks sway bar reinforcement kit. what's the difference?
http://www.beaksproducts.com/S...t.htm
Old Apr 4, 2007 | 09:42 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Design for Sway bar Braces (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">looks exactly like the beaks sway bar reinforcement kit. what's the difference?
http://www.beaksproducts.com/S...t.htm</TD></TR></TABLE>
His is cheaper and made by him.
Old Apr 4, 2007 | 01:57 PM
EG-Honda's Avatar
Default Re: Design for Sway bar Braces (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
Old Apr 4, 2007 | 01:59 PM
EG-Honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">looks exactly like the beaks sway bar reinforcement kit. what's the difference?</TD></TR></TABLE>
I don't see beaks giving you the drawing to make it yourself!
Old Apr 4, 2007 | 03:29 PM
JSPECSIR's Avatar
damn thats a great price.
Old Apr 5, 2007 | 05:39 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-Honda &raquo;</TD></TR><TR><TD CLASS="quote">
I don't see beaks giving you the drawing to make it yourself!</TD></TR></TABLE>
HEY MAN RELAX! i was just asking a simple question, no need to get bent out of shape.
Old Apr 5, 2007 | 06:38 AM
EG-Honda's Avatar
HEY MAN RELAX! i was just asking a simple question, no need to get bent out of shape. </TD></TR></TABLE>
Old Apr 5, 2007 | 06:55 AM
oOoEG6oOo's Avatar
pretty good diy...
Old Apr 5, 2007 | 08:03 AM
d357r0y's Avatar
Looks good
Now make one that relocates the swaybar so it doesn't hit my thermal exhaust
Old Apr 5, 2007 | 09:47 AM
suspendedHatch's Avatar
Default Re: Design for Sway bar Braces (d357r0y)
Or you could just buy the Progress 24mm rear adjustable sway and save your subframe and a ton of money.
Old Apr 5, 2007 | 10:21 AM
d357r0y's Avatar
Default Re: Design for Sway bar Braces (suspendedHatch)
I don't think I need a 24mm bar for mostly street driving. I have yet to find a picture of a 3" thermal exhaust with a rear swaybar on a hatch. (that doesn't need some sort of modifying)
Old Apr 5, 2007 | 10:50 AM
xunsungheroesx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-Honda &raquo;</TD></TR><TR><TD CLASS="quote">not a bad idea, but in the stress testing it only affected very high loads. </TD></TR></TABLE>
Um... that's the point of adding the fillet. Those sharp corners act as stress concentrators and a greater curvature reduces this effect. Depending on the state of stress and the load this thing is under, it may/may not be necessary. I'm not sure if you are saying that you wouldn't add it because it only relieves highly loaded areas or if you are saying that you don't need it because testing showed that the stress at that area didn't exceed the strength of the material. Anyway, if it's the former, then you should consider redesigning it with the fillet. If it's the latter, then it was just some good advice from 94eg!.
Old Apr 5, 2007 | 12:48 PM
EG-Honda's Avatar
Default Re: Design for Sway bar Braces (xunsungheroesx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xunsungheroesx &raquo;</TD></TR><TR><TD CLASS="quote">
some good advice from 94eg!. </TD></TR></TABLE>
Good advice indeed. That's the beauty of DIY, you have the information to do it how you like.
Here are pics of the stress results between a fillet and not fillet.
NO FILLET
WITH FILLET
This was done with a calculated force of 1000 lbs. Which I feel is High. You can see that the fillet does not change much, as the clear weaknes of the design is the span and restriction of part thickness. Sure you could make it thicker, but then you start having alignment issues with the sway bar.
Old Apr 5, 2007 | 12:57 PM
racer_X_123's Avatar
Love the DIY... Cool pics also.. You should re-design the ASR one and put that in your stress test and see how it compares...
Thought i saw a thread awhile back that someone did that, but cant recall...
Old Apr 5, 2007 | 01:12 PM
EG-Honda's Avatar
Default Re: Design for Sway bar Braces (racer_X_123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racer_X_123 &raquo;</TD></TR><TR><TD CLASS="quote">Love the DIY... Cool pics also.. You should re-design the ASR one ...</TD></TR></TABLE>
Already ahead of you...need to verify hole locations before I relase it though. The ASR one is deffinetly overkill for the application. I belive the best way to go is to make it as light as possible. This is a pic of the first go around.
Old Apr 5, 2007 | 01:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-Honda &raquo;</TD></TR><TR><TD CLASS="quote">Already ahead of you...</TD></TR></TABLE>
If i had to guess, ASR would have made it that big in order to distibute the load throughout the entire peice of aluminum. Cant wait for the results.
Old Apr 5, 2007 | 01:42 PM
Eran's Avatar
HT White Ops
The ASR one weighs like 5 lbs and is solid.
I'd rather have a solid piece that weighs 5lbs than a perforated pieces that weighs 2-3lbs.
