is it illegal to drive without a heat shield on the CAT?
Old Apr 3, 2007 | 07:06 AM
dohc-father's Avatar
Default is it illegal to drive without a heat shield on the CAT?
my bottom half of the heat shield broke off because of rust or whatever, my car is rattling so ****** bad that the top half is just rubbing on it... Am i able to take it off if i got under my car or do i have to take it to a shop?
Old Apr 3, 2007 | 07:11 AM
Blk00EJ8's Avatar
Default Re: is it illegal to drive without a heat shield on the CAT? (dohc-father)
You mean the one on the cat itself or the one on the chassis above the cat? The one on the chassis is just held on with 2 measly 10mm bolts and they tend to rust off. So yea, that's easy to take off.
Old Apr 3, 2007 | 07:15 AM
blackdelslo's Avatar
Default Re: is it illegal to drive without a heat shield on the CAT? (Blk00EJ8)
I doubt its illegal. I wouldn't worry about it as if anyone did see that you didn't which would be hard for them to, I doubt anyone would care, including a cop.
Old Apr 3, 2007 | 07:24 AM
THC07's Avatar
you'd be surprised, im pretty sure that if you were to go see a california Ref, he would tell you to get a cover as a fire precaution. In NJ i dout you will have any problems.
whats with the sig Blk00?
Old Apr 3, 2007 | 08:16 AM
redline5th's Avatar
Ah, it really depends on where you are.
Old Apr 3, 2007 | 11:02 AM
I TRIED TO TAKE IT OFF... BUT THE ONE DAMN NUT IS RUSTED THAT I COULDNT TAKE IT OFF. IM JUST GONNA TAKE IT TO A MUFFLER SHOP AND HAVE THEM REMOVE IT. ITS TOO MUCH OF A HASSLE. THE TOP SHIELD IS VIBRATING AND IT IS ANNOYING!!!
Old Apr 3, 2007 | 12:10 PM
thesmogman's Avatar
Default Re: (dohc-father)
What I use to do on the old Ford rangers is get a coathanger and wrap it tight as you can to hold it from vib'ing.
Old Apr 3, 2007 | 01:28 PM
JDM-EJ1's Avatar
Default Re: is it illegal to drive without a heat shield on the CAT? (blackdelslo)
I don't have one.
Old Apr 3, 2007 | 01:30 PM
ke98248's Avatar
Default Re: is it illegal to drive without a heat shield on the CAT? (JDM-EJ1)
use a grinder and grind off the bolt then yank the shield off
Old Apr 3, 2007 | 01:31 PM
JDM-EJ1's Avatar
Default Re: is it illegal to drive without a heat shield on the CAT? (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">use a grinder and grind off the bolt then yank the shield off</TD></TR></TABLE>
Or, just remove the cat; remove the bolts that hold it on to the cat and than remove the one that is on the bottom of the chassi.
Old Apr 3, 2007 | 01:35 PM
ke98248's Avatar
Sure, if he wants to do that, either way works. But he said the bolts were rusted so I'm offering the fastest solution..
Old Apr 3, 2007 | 02:22 PM
stephen_civic98's Avatar
Use PB Blaster on it, and a big pipe on the end of your socket wrench.
Old Apr 3, 2007 | 04:25 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Default Re: (stephen_civic98)
LOL how can he do that if the bolts are rusted off?
Old Apr 3, 2007 | 04:53 PM
he didnt say it was rusted off, just rusted on. He might have a small chance of getting them off with bp blaster and a pipe if not, then he is going to have to cut them ether way.
Old Apr 3, 2007 | 05:56 PM
Blzdeep's Avatar
Default Re: (thesmogman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">What I use to do on the old Ford rangers is get a coathanger and wrap it tight as you can to hold it from vib'ing.</TD></TR></TABLE>
haha thas so ghetto i love it ... if you find a cop to get under your car to see if the cat has the heat shield ..... lemme know so i dont go there
Old Apr 3, 2007 | 06:03 PM
STG_PeteJ2's Avatar
no its not
Old Apr 3, 2007 | 06:09 PM
BAMF_SOHC's Avatar
Default Re: (STG_PeteJ2)
If your sick of it vibrating just take some huge worm clamps and bam nomore rattle, thats what I used to do when i worked for honda that or rip it off...lol
Old Apr 3, 2007 | 06:30 PM
F'NfastSOHCturbo's Avatar
Its as illegal as having sex w/o a condom I heard.....
Old Apr 3, 2007 | 06:52 PM
My b i have a drinking problem and can not read sometimes.
Old Apr 3, 2007 | 07:04 PM
EK 2 9K's Avatar
screw two hose clamps together to make them longer and tie two of the clamps one and each end. need a total of 4 clamps
Old Apr 3, 2007 | 08:10 PM
92slowcivic's Avatar
Default Re: is it illegal to drive without a heat shield on the CAT? (EK 2 9K)
i couldnt get the bolts off my cat heat shield so i just crawled under the car and cut it off with tin snips. kind of a pain, you gotta cut by the bolts and by the o2 sensors. only took a few minutes though.
Old Apr 4, 2007 | 01:50 AM
thanks for all the ideas fellas, is the CAT flammable? lets say if i rope tied it for a day or so? cause i need to make time to get to an exhaust shop to get that bad bot removed. its buggin the hell out of me!!!!!
Old Apr 4, 2007 | 02:21 AM
slowpokecivic's Avatar
in CA, it is not illegal to remove the heatshield from the cat...
i barred without one on mine...
J-HAWK
Aug 22, 2007 10:37 PM
jagged4698
Apr 13, 2004 06:18 PM
onyx00
Jul 21, 2002 06:38 PM
newt2
Apr 20, 2002 01:52 PM
Maengelito
Apr 10, 2002 06:41 PM
