obd1 engine not running right in obd2 car
Old Apr 3, 2007 | 05:39 AM
hksdrager's Avatar
Default obd1 engine not running right in obd2 car
i put a d16z in 98 civic ex the knock sensor is left hanging and so is the ckf i think its called. i bought the jumper harness and hooked up the p06 ecu i know its not vtec i just wanted to see if it runs. well it blows out smoke and revs up and down over and over. thanks
Old Apr 3, 2007 | 08:18 PM
hksdrager's Avatar
Default Re: obd1 engine not running right in obd2 car (hksdrager)
bump
Old Apr 3, 2007 | 09:06 PM
92slowcivic's Avatar
doesnt the p06 control the d15b7? (usdm) wouldnt it not work then, on the d16z? i dont know off the top of my head what ecu is for the d16z. hell, for all i know, the p06 will do it. anyway, i know i had the p06 running my stock d15b7 so it seems rational, at least to me, that it might not work correctly on the d16z. just spit balling here. anyone know what ecu should be running the d16z?
Old Apr 3, 2007 | 09:15 PM
TegProject's Avatar
Default Re: obd1 engine not running right in obd2 car (92slowcivic)
yeah the stock ecu for the y8 or the z6 is the p28. You can chip the p06 to work the exact same as a single cam p28 though.
Old Apr 3, 2007 | 10:03 PM
Default Re: obd1 engine not running right in obd2 car (TegProject)
thats what i thought. i didnt think plugging in the p06 "just to see if it runs" would really accomplish anything since the computer is not made to control the d16z.
Old Apr 4, 2007 | 05:29 AM
hksdrager's Avatar
ok ill try the p28
Old Apr 4, 2007 | 05:53 AM
THC07's Avatar
Default Re: (hksdrager)
changing the ecu will not effect the idle much. you should be able to idle with a p06. the only difference you should notice is no vtak.
Old Apr 4, 2007 | 06:22 AM
JDMFantasy2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TegProject &raquo;</TD></TR><TR><TD CLASS="quote">yeah the stock ecu for the y8 or the z6 is the p28. You can chip the p06 to work the exact same as a single cam p28 though. </TD></TR></TABLE>
z6 uses a p28, y8 uses a p2p
you guys need to realize that just because they're all 1.6 sohc motors doesn't mean you can use any computer. The y8 and z6 are pretty similar but do have different timing requirements. So get a p28 and do it right.
DaddyKin
14
Jul 12, 2011 01:52 PM
gsr_b20b
Sep 22, 2010 09:40 AM
Blahblah718293
May 3, 2010 08:41 PM
boostedjdmdc2
12
Mar 7, 2008 10:09 PM
hYbRid_Eg6
Jul 31, 2005 09:36 PM
