RSX seats in CRX?
Old Apr 3, 2007 | 01:14 AM
black88si's Avatar
Default RSX seats in CRX?
Just as a reference for anyone who wants to do this. They do fit, I wouldn't recommend them if you are much over 6 feet, as they sit kinda high (unless you weld in new seat pans)
These only took me a little while, without much effort or money.
Old Apr 3, 2007 | 01:42 AM
sneakerfern's Avatar
Default Re: RSX seats in CRX? (black88si)
Old Apr 3, 2007 | 01:53 AM
Maldito X's Avatar
how much higher? i like the low seating of the crx.
Old Apr 3, 2007 | 04:01 AM
harmonator84's Avatar
Default Re: (sLcREX)
Almost all seats set up too high..other than crx seats.
Old Apr 3, 2007 | 04:04 AM
VegaS10's Avatar
My old rex.
R.I.P.
Old Apr 3, 2007 | 04:23 AM
user 72830283's Avatar
were those side airbags still in tact?
Old Apr 3, 2007 | 04:28 AM
VegaS10's Avatar
Yes, mine were.
Old Apr 3, 2007 | 06:20 AM
YZFR6's Avatar
That looks sweet
Old Apr 3, 2007 | 07:28 AM
HondaHeddie's Avatar
Default Re: RSX seats in CRX? (YZFR6AVID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YZFR6AVID &raquo;</TD></TR><TR><TD CLASS="quote">That looks sweet </TD></TR></TABLE>
x2
I will look into this
I would like to see a write up
and if anyone would write up how to make the mod to allow the RSX seats to sit low it would rok
Old Apr 3, 2007 | 10:16 AM
black88si's Avatar
Default Re: RSX seats in CRX? (HondaHeddie)
That requires welding new seat pans in. When I do mine I will make a lil write up. Probably going to be a while, I still have to buy a welder.
The seats probably sit one or two inches higher than CRX seats. In order to get them in, (without welding that is) you have to cut the 2 rear mounting holes off, and make thin brackets that can bolt into the rear seat holes, and sorta pinch the rails down. (not the best, but worked pretty well for me). You also want to elongate the front mounting holes upward, instead of circles you want them to be vertical ovals. This will help keep the seats a little bit lower (if you dont drill the holes larger the seats will touch the headliner)
Old Apr 3, 2007 | 10:26 AM
BERT-O's Avatar
Wow!
Semi matches the door interior! Good job
Old Apr 3, 2007 | 10:42 AM
black88si's Avatar
Default Re: RSX seats in CRX? (BERT-O)
Its pretty close. You can't tell the difference in the day light (flash is super bright)
Even though they sit a lil higher, they are still 100x better than the CRX seats were.
Old Apr 4, 2007 | 07:47 PM
Project-Honda's Avatar
i just put in sum ep3 seats in my ef9 and they sit the highest and im a pretty big guy, almost 6ft 215 pounds and my knees are against the steering wheel, it sucks but it looks sick though, and urs looks pretty nice any fabricating?
Old Apr 4, 2007 | 08:48 PM
Slurp56's Avatar
Default Re: (harmonator84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">Almost all seats set up too high..other than crx seats.</TD></TR></TABLE>
I've tried Sparcos Torino's, 92-95 civic seats, 96-00 civic seats seats, and 94-01 Integra seats. All sat too high. Those RSX seats look like they sit way too high as well.
Del Sol's are a really good fit. I used the top half of the del sol rail and the lower half of the CRX rail. Made for a bolt in seat swap that sits low to the ground.
Old Apr 4, 2007 | 09:01 PM
gospeedgo1's Avatar
Default Re: (Slurp56)
i just put f1spec seats in my crx si a month ago. i was hitting my head on the roof of my crx all the time. my head hits the roof normally. now im about 2 inches from the roof. id say i dropped around 3 inches and have lots of leg room, head room.
Big Si Guy
11
Aug 22, 2015 05:41 AM
xaine
Apr 27, 2009 07:50 PM
ryan_crx
20
May 2, 2008 03:53 PM
bassofbob
Feb 20, 2006 07:08 PM
