very low gas milage..
Old Apr 2, 2007 | 11:30 PM
salman's Avatar
Default very low gas milage.. 11mpg
Finally checked the MPG.
Drive under 3k rpm,
Getting 17 MPG
City Driving with vtec 25 to 30%
Getting 11.5MPG...
getting 15 to 18 MPG.
80% I drive with vtec,
Have a chiped ECU, in which I have increased the fueling 1% in high cam after 5k RPM,
The only code I have, 30 which is auto tranny signal code, which is a crome bug, some times comes,
it cant be removed if i rebured the chip,
else i have no codes, every thing is ok,
when i did this swap 2 of my injector got stucked so i washed then WD-40, they become ok.
I dont have any problem with the car. runs gr8.
I have Denso iradium plugs,..
2.25" straight pipe,
chiped P06 with Vtec.
Velocity Stack,
let me know where i can check for the cause.
Thanks.
Modified by salman at 1:41 AM 4/9/2007
Old Apr 3, 2007 | 08:52 AM
goforbroke's Avatar
MEAT PATTY
Default Re: very low gas milage.. (salman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">getting 15 to 18 MPG.
Their lies your problem.........
Your chipped computer probably isn't helping either.
Old Apr 3, 2007 | 08:55 AM
salman's Avatar
Default Re: very low gas milage.. (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">
Your chipped computer probably isn't helping either.</TD></TR></TABLE>
Nah, its me who remain in vtec zone most of the time.
Old Apr 3, 2007 | 10:12 AM
Relic1's Avatar
I have a feeling that the weight of your right foot is to blame.
keep out of VTEC and your mpg will increase a lot.
how about tuning? been done? it makes a difference...
NOTE: I pulled ~10-12mpg on the track my last outing, so 15-18 when in VTEC 80% of the time is not all bad.
Old Apr 3, 2007 | 09:44 PM
salman's Avatar
people are getting 30 MPG even with 40 mpg.
i am just hoping to get 25 mpg with vtec,.
Old Apr 3, 2007 | 09:51 PM
dude_123's Avatar
Default Re: (salman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">people are getting 30 MPG even with 40 mpg.
i am just hoping to get 25 mpg with vtec,. </TD></TR></TABLE>
No chance, probably that turbonator might help . But, honesly, 30-40 mpg is from driving old ppl speed not high speed driving or in vtec. Getting 30 mpg in vtec (not econo vtec), damn they are sure smoking some good **** or just blowing a whole load of smoke up the ***.
Old Apr 3, 2007 | 10:31 PM
92TypeR's Avatar
FSAE
Default Re: (dude_123)
I get 25-27mpg consistantly on my 12:1 2.0L, thats even with a 4.9 final drive.
It is all about the partial throttle tune. I tune a little on the lean side during partials. 15:1-15.5:1
I like to drive too. So I'm definately not 'trying' to be fuel efficient.
Old Apr 3, 2007 | 11:30 PM
salman's Avatar
Default Re: (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">I get 25-27mpg consistantly on my 12:1 2.0L, thats even with a 4.9 final drive.
Above i mentioned that i have heavy foot, but most of the time i am driving below vtec range,
in the above menstioned avarage, 4 times I have done 0 to 100 checks, else i have driven slow.
Old Apr 4, 2007 | 02:09 AM
Group Tenacity's Avatar
never mind
Old Apr 4, 2007 | 02:49 AM
salman's Avatar
heheh. when u'll find gas for 5$ per gallon, u'll start to mind.
Old Apr 4, 2007 | 03:45 AM
98vtec's Avatar
moderator emeritus
so then engine has not been tuned?
Old Apr 4, 2007 | 09:02 AM
Relic1's Avatar
first post
80% I drive with vtec, </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">Above i mentioned that i have heavy foot, but most of the time i am driving below vtec range,
in the above menstioned avarage, 4 times I have done 0 to 100 checks, else i have driven slow. </TD></TR></TABLE>
so which is it?
if you're pulling 15-18mpg and keeping below the VTEC range most of the time that is bad. I pull 30mpg mixed driving (tuned ITR swap) and I'll bet I average pushing at least once a day. (depending on my mood)
Check your O2 sensor. Tune the car.
Old Apr 4, 2007 | 11:14 PM
salman's Avatar
Default Re: (Relic1)
the car is not tuned.
i am using friends bin file.
Old Apr 5, 2007 | 03:18 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">the car is not tuned.
get it tuned
Old Apr 5, 2007 | 03:35 AM
salman's Avatar
i dont have tuner here, I am thiking to try stock JDM b16 bin,
Old Apr 5, 2007 | 05:34 AM
98vtec's Avatar
moderator emeritus
go back to the stock ecu.......
Old Apr 5, 2007 | 08:06 PM
salman's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">go back to the stock ecu.......</TD></TR></TABLE>
Dont have one,
Old Apr 7, 2007 | 06:57 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">i dont have tuner here, I am thiking to try stock JDM b16 bin,</TD></TR></TABLE>
what engine do you have? a B16? then go for it.
Anything else it's not a good idea.
Old Apr 7, 2007 | 10:07 AM
salman's Avatar
its a b16 with I/E. in hatch back civic
Old Apr 10, 2007 | 03:19 AM
salman's Avatar
up.
Old Apr 11, 2007 | 02:30 AM
EnjoyTheRideDC2's Avatar
i am using friends bin file. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">its a b16 with I/E. in hatch back civic</TD></TR></TABLE>
Forget getting your car tuned. Run the stock b16 bin file on your ecu. Intake and exhaust aren't enough to need tuning on a stock b16.
Is your friend running a stock b16 with intake and exhaust? Even if he was, every engine is different. There isn't really a universal chip that'll yield the same results on everyones car. Dont waste your time running someone elses bin file. Just run the stock b16 bin and call it a day.
Old Apr 11, 2007 | 07:57 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">I am thiking to try stock JDM b16 bin,</TD></TR></TABLE>
the best idea
it will run better and get better mpg.
Old Apr 16, 2007 | 08:32 PM
salman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">
the best idea
it will run better and get better mpg.</TD></TR></TABLE>
IF it runs batter with that, i am on it,.
GottaDC2
Jun 21, 2008 10:14 AM
951dc5
Jun 4, 2005 09:51 AM
evilone
Sep 25, 2004 03:23 PM
y2ks2k
Nov 8, 2003 01:11 AM
turbotime
Jul 29, 2003 03:23 PM
