NEED HELP.... F22 SWAP in 95 LX
Old Apr 2, 2007 | 10:06 PM
splmike15's Avatar
Default NEED HELP.... F22 SWAP in 95 LX
i bought a 95 accord LX w/ a screwed auto tranny so i went out and looked and found a motor,tranny, ECU, axles, pedals, shift linkage and everything to convert over. how hard would this be??????????????? has any 1 done this before?????????? if so i need help. thanks
splmike15's Avatar
Default Re: NEED HELP.... F22 SWAP in 95 LX (splmike15)
also the new motor is out of a 1995 EX SOHC V-tec.
Old Apr 2, 2007 | 10:13 PM
Twixle's Avatar
ate my pixel
The only thing different than your stock motor is the tranny (obviously), the actual head on the engine block, and the ECU. Try looking in the stickies up top, or do a search, there's a few people who have done this.
The axles are going to be the same.
Old Apr 3, 2007 | 05:32 AM
splmike15's Avatar
Default Re: NEED HELP.... F22 SWAP in 95 LX (accord2021)
hey thanks man
Old Apr 3, 2007 | 06:23 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord2021 &raquo;</TD></TR><TR><TD CLASS="quote">The axles are going to be the same. </TD></TR></TABLE>
I could be wrong but I'm pretty sure the automatic tranny doesn't use a half shaft and axle but instead uses a single axle from the tranny to the hub (this is on the driver side of course).
OP:
Like accord 2021 said, check the FAQ. There are links that will assist you in what you are trying to do. For both the motor swap and the auto-to-manual tranny swap.
Shooter4
Jan 16, 2016 02:18 PM
cehcivic15
13
Sep 4, 2008 11:19 AM
freakasis
Apr 18, 2006 10:34 AM
The Airman
Dec 29, 2004 05:44 AM
DigitalFusion
Aug 9, 2004 09:49 AM
