Suspension & Brakes Theory, alignment, spring rates....
Sagging front after installing h&r race springs
Old Apr 2, 2007 | 08:37 PM
GraphiteMW's Avatar
Default Sagging front after installing h&r race springs
Installed h&r springs on my 92 lude. Dropped the front noticeably by allot.. the rear is exactly how I want which just a finger gap. but the front is TUCKING stock oem 15's. Its tucking about .25" on one side and the other is tucking .5". I can't figure out whats wrong..
I am thinking blown OEM front struts? ? ? I doubt they could be worn springs since the h&r race's are pretty stiff springs right? I also installed them correctly installed the ones labeled R in the rear which were reasonably long with lots of coils and installed the shorter ones in the front which were labeled F. Installed correctly?
Modified by GraphiteMW at 12:49 AM 4/3/2007
Old Apr 2, 2007 | 09:07 PM
GraphiteMW's Avatar
well the ones labeled F were short and not really any thicker then the ones labeled R.. The ones labeled R had a bunch of coils that were close together on the top and was definitely a bit longer.
I installed my springs upside down from this.. Maybe I have them upside down? Would that affect the height?
Heres a Pic I took when I first got them
I basically installed the front springs on how they are standing on my bed.
Old Apr 2, 2007 | 10:45 PM
vtec770's Avatar
Default Re: (GraphiteMW)
yes small coils on top... ALWAYS. as for one side being a lil higher than the other i have no idea. i just figured the motor is mostly on the driver side so thats probably the reason why the driver side is a lil lower but once again i dont know the real reason. i just bought coilovers and set them even. lol
Old Apr 3, 2007 | 10:34 AM
GraphiteMW's Avatar
Default Re: (vtec770)
So your saying in the first picture is how I was supposed to install it? The smaller coils on top and coils with a wide diameter on bottom?
Old Apr 3, 2007 | 12:54 PM
vtec770's Avatar
no in the first picture they are upside down. the coils that are colse together go on top the coils thats a farther apart go on bottom. in the second picture: the 2 that are standing up are correct.
kloscivicsi
Honda Civic (2006 - 2015)
Feb 1, 2008 06:14 PM
silentbeatz
Suspension & Brakes
May 6, 2005 07:36 AM
LSBlackInteg
Apr 11, 2003 06:21 PM
WangChung
Feb 13, 2003 02:16 AM
oldbeefcake
Jun 5, 2002 07:22 AM
