Deck keeps poping out everytime hit WOT.. how to fix?
Old Apr 2, 2007 | 08:32 PM
J.nguyen's Avatar
Default Deck keeps poping out everytime hit WOT.. how to fix?
my deck & other thing keeps poping out everytime i hit WOT in my car, ive never had this problem in any of my integras before.. i have no clue how to fix this and still make it look clean.. any products or tips or inventions / DIY taht can make the deck stay put ..
Old Apr 2, 2007 | 08:44 PM
MaltBeer's Avatar
Default Re: Deck keeps poping out everytime hit WOT.. how to fix? (J.nguyen)
on my DA i have 4 zip ties and have it go through the plastic part of the deck and tie it around something strong in the back
Old Apr 2, 2007 | 09:37 PM
J.nguyen's Avatar
Default Re: Deck keeps poping out everytime hit WOT.. how to fix? (MaltBeer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaltBeer &raquo;</TD></TR><TR><TD CLASS="quote">on my DA i have 4 zip ties and have it go through the plastic part of the deck and tie it around something strong in the back</TD></TR></TABLE>
hMm hows hta tlook? u secured the zpi ties to the Silver thing that goes around the DECK ?
btw i have a JVC..
Old Apr 2, 2007 | 10:55 PM
solareclipseauto's Avatar
use a back strap-connects the back of the deck to the frame of the car behind the deck, also makes the deck harder to rip out when someone tries to jack you
Old Apr 3, 2007 | 12:49 AM
J.nguyen's Avatar
Default Re: Deck keeps poping out everytime hit WOT.. how to fix? (solareclipseauto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solareclipseauto &raquo;</TD></TR><TR><TD CLASS="quote">use a back strap-connects the back of the deck to the frame of the car behind the deck, also makes the deck harder to rip out when someone tries to jack you</TD></TR></TABLE>
any link pic or info on this? i know u do that in san diego car audio and tint, but wondering how much is that thing u are talkiin about.. my next method was thinki of just drillin some holes on the inside and bolts and screws.. but that would be PITA to take out and put back in..
Old Apr 3, 2007 | 06:26 AM
go to any stereo shop and tell them you looking for a bracket for a back strap. you screw one side to the back of the deck and then you a self tapping screw on the other end to hold it to the frame.
Old Apr 3, 2007 | 07:13 AM
kinick313's Avatar
More info needed....
If its an oem deck, then the bolt holding the deck in place in the rear is missing or has fallen out
If its an aftermarket, then follow this procedure:
1. Carefully pull deck out (wiggle a bit and it should pop out)
2. Remove deck from the box housing it is clipped into
3. put the metal housing back into the deck slot in your dash
4. bend the triangular tabs outward from the center of the housing so that the housing is securely in place
5. Put head unit back in
the other fixes above, while not necessary, you should consider doing anyways. just makes the thing more secure and harder to steal.
from the research I've done, there aren't any good brackets for the integra available. A good one would replace that metal housing with a longer one with a bolt hole on the bottom so that the head unit could be bolted down like the oem radio. Frankly, it amazes me that no one makes a good kit, as out cars are broken into much more frequently than others out there. I plan on custom fabbing a bracket for myself, but you can get away with my procedure listed above.
EDIT: saw you have a jvc... disreguard the oem mention.
Old Apr 3, 2007 | 04:31 PM
importdude2000's Avatar
mine is taped the the center shorud
never comes out its rock solid
Old Apr 3, 2007 | 04:37 PM
20ls01's Avatar
vtak is too strong
Old Apr 3, 2007 | 05:59 PM
Vtec_Dude's Avatar
damn your car is strong....that happened to me too on all the cars that i had or known almost. Simple taping will fix it. haha, j/k if you find a way tell me.
Old Apr 3, 2007 | 10:44 PM
J.nguyen's Avatar
Default Re: (kinick313)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinick313 &raquo;</TD></TR><TR><TD CLASS="quote">More info needed....
EDIT: saw you have a jvc... disreguard the oem mention.</TD></TR></TABLE>
i did this, it worked! but only problem is now the "deck" comes out a lil but it still stays in, the casing is firm , but the actual deck slips out, but i just baught chain from hom depot and gonna bolt / washer them to frame so it stays TIGHT and thieves cant jack it
Old Apr 3, 2007 | 11:19 PM
mtpktz.'s Avatar
Default Re: (J.nguyen)
I thought you sold the car?
Old Apr 3, 2007 | 11:25 PM
J.nguyen's Avatar
Default Re: (mtpktz.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtpktz. &raquo;</TD></TR><TR><TD CLASS="quote">I thought you sold the car?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.nguyen &raquo;</TD></TR><TR><TD CLASS="quote">
damn my car was suppose to be sold!!, but small *** world, he was suppose to buy my car on monday, but then he doesnt call me on monday,then today my good homie calls me ( he recently moved from san diego to las vegas ) and
asks me
"was LJ the guy that was suppose to buy ur car? cause i think he told me he was suppose to buy ur car, but he ended up driving all the way to my house with his parents and he baught my car for 11k+"
so car is still up for sale *damn i shoulda just sold it on sunday when he wanted to come down to buy it, but i had a feelin i couldnt trust him (his myspace said he use to 'break ignitions') so i wanted to wait till monday for bank to open.. kinda regretting that now.. o well as long as he baught one of our cars its all good
Old Apr 4, 2007 | 12:01 AM
Stein's Avatar
I took a couple washers and shoved them between the deck and the plastic connectors on the side, stays put now .
Old Apr 4, 2007 | 03:48 AM
be.twenty's Avatar
the metal bracket that the deck sits in has tabs that you should be able to bend outwards. this keeps the bracket locked in place and the deck locks into the bracket.
Old Apr 4, 2007 | 07:36 AM
kinick313's Avatar
glad i could help man...
I've seen some people get those little aluminum strips with a bunch of holes in them (i think they're used in plumbing - anyone know what i'm talking about?) and strap it too the back of the headunit and back to the bolt that holds the stock radio.
the strips im talking about are about 1.5 cm wide... any length, and the holes are about 1cm thick. you can pick them up at home depot.
Old Apr 4, 2007 | 07:42 AM
mac_24_seven's Avatar
Default Re: (20ls01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 &raquo;</TD></TR><TR><TD CLASS="quote">vtak is too strong</TD></TR></TABLE>
Yeah, I was gonna say go buy an LS Problem solved.. heheheh
VR_GS-R
Audio / Security / Video
Sep 9, 2006 10:03 AM
initialvtec
Mar 14, 2005 03:16 PM
Uneekpinoysk8er
Feb 1, 2005 02:54 PM
Horatio
18
Sep 7, 2003 08:06 PM
sittinhighon33s
Nov 26, 2002 01:07 PM
