My car wouldn't start
Old Apr 2, 2007 | 07:39 PM
cvam's Avatar
Default My car wouldn't start
My car is 97' Honda Civic LX was ran out of gas. After fill up gas, my car wouldn't start.
I checked the following are ok:
- Spark Ok.
- Gas came out to engine.
Can anyone tell me, what should I do plz.
Old Apr 2, 2007 | 08:31 PM
deadline's Avatar
are the injectors okay ?
Old Apr 3, 2007 | 01:35 AM
mmbonbons's Avatar
Default Re: My car wouldn't start (cvam)
battery needs to be charged? does the ignition click?
Old Apr 3, 2007 | 07:00 AM
cvam's Avatar
Default Re: (deadline)
injectors ok.
Old Apr 3, 2007 | 07:03 AM
cvam's Avatar
Default Re: My car wouldn't start (mmbonbons)
my battery is fully charged and also the ignition click, but still the car wouldn't start.
the main relay is also ok, make 3 click, 1st 2 click and last one when I try to start the engine.
Old Apr 3, 2007 | 09:48 PM
grizzman's Avatar
hey whats up. so the car ran out of gas totally. Your battery is charged. if everything else was fine when you last drove it besides the gas issue. you need to remember when you empty your tank fully then put gas and try to start it. it takes a pretty good amount of cranking the motor to get the fuel system back to full and the pressure back to normal. you could try sprying starting fulid into the throttle body at the butterfly valve to help it start and pressurize the system that way. but the motor needs to be cranking somehow to pressureize the system. because the fuel pump only runs when the motor is being cranked. it has to push fuel in order to stay cool or it could over heat and burn out. hope all this info helps.
Old Apr 3, 2007 | 09:57 PM
smileycvc's Avatar
Default Re: My car wouldn't start (grizzman)
^^^What?? The fuel pump primes itself as soon as you turn the key which pressurizes the system. The motor does not need to be cranking. Also fuel doesnt cool the motor or starter.
Old Apr 4, 2007 | 12:22 PM
grizzman's Avatar
Default Re: My car wouldn't start (smileycvc)
The fuel system does prime its self but thats when you have not ran it out of gas completely. because the fuel relay shuts the pump off after 2-3 seconds after its primed so unless you want to sit there and turn the key on and off about a million times then go ahead and dont listen to me. And i said that the fuel pump must be pumping fuel for it to not overheat and burn out. I said nothing about the motor or starter burning out?
juanambriz7
Nov 21, 2007 04:56 PM
Chee_dog
Nov 19, 2007 05:21 AM
SHAQ1
Oct 30, 2007 01:23 PM
datssoled
Jul 12, 2007 04:14 PM
1991rexSI
Apr 16, 2006 05:46 PM
