HELP. my first 'noise.'
coming home from work tonight i noticed a noise coming from the front of my car. almost sounds like playing cards in bicycle spokes. i only hear it when i'm moving, neutral or in gear. i got out, looked around under the car with my flashlight, didnt see anything abnormal. nothing rubbing on any of the tires/wheels. it runs great, trans is smooth in and out of every gear. i cant think of anything. anyone have anything in mind or have something similar happen? any ideas would be appreciated. TIA.
Anymore info? What general area is it coming from?
Is this on the B18 w/ stock tranny?
edit: BTW, don't ******* bump after 12min. You've only had 10 views.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">Anymore info? What general area is it coming from?
edit: BTW, don't ******* bump after 12min. You've only had 10 views.</TD></TR></TABLE>
yeah stock b18c/stock itr trans. it sounds to me like its coming from the trans, but i'm not sure.. i can only lean over so far when i'm driving.
about the bump, i'm about to call it a night and i wanted some ideas beforehand.. sorry to offend you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">What clutch are you running, and how many miles are on it? Maybe the springs are damaged, maybe it's the throwout bearing.</TD></TR></TABLE>
i bought the car back in october, so i havent had it very long. previous owner tells me its an act 'stage 3.' not sure of the specifics, the motor only has about 70,000 miles on it, so i dont think the clutch has many miles on it. i was leaning in the direction of a bearing, sounds pretty typical... the faster i go the faster the noise gets; almost gets to like a whirring sound, like a wheel bearing but not quite as pronounced.
tap tap tap pistons
or axle if the axle is broke you can still drive if it is the driver side... and will even make the noise if you are in neutral
Are you referring to rod knock?
http://www.youtube.com/watch?v=DfJIpiQZtR4
http://www.youtube.com/watch?v=M1sxt3BC1TE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaman816 »</TD></TR><TR><TD CLASS="quote">tap tap tap pistons
or axle if the axle is broke you can still drive if it is the driver side... and will even make the noise if you are in neutral</TD></TR></TABLE>
no, the engine is fine. it ran great on the way home. sounds completely normal when i'm revving it. could be an axle problem, but i'll have to wait until tomorrow and put it up on a lift.
doesnt sound like the motors in those videos ^^
91b16acrx
13
Jan 8, 2005 12:06 PM
