92eg suspension fit 96ek?
yes, you just just need a couple of washers per fork for the rear since the LCA bushings on the rear are narrower on the EK than the EG... You can get 3/8" fender washers from home depot for a few cents a piece.
fender washers and cut washers are both flat. Fender washers come in a variety of outer diameters whereas cut washers are pretty much have a set out diameter for whatever size hole you get, i.e. 3/8"
MethodR
Oct 26, 2005 02:39 AM
