Radiator Fan (jump start?)
Old Apr 2, 2007 | 03:23 PM
ahemming06's Avatar
Default Radiator Fan (jump start?)
Have a 96 integra GSR and Ive never seen or heard the fan kick on even on the hottest days. Granted, the engine temp never rises but I still want to see If I can jump the fan to the battery to make sure it works..
What is the best way to do this? Can't I just take two wires and connect them from the battery terminals to the plug coming off the fan?
Old Apr 2, 2007 | 03:25 PM
HAPRECYCLING's Avatar
Default Re: Radiator Fan (ahemming06)
YOU CAN DO THAT OR JUMP THE PLUG THAT GOES TO YOUR FAN SWITCH. YOUR FAN SHOULD TURN ON.
Old Apr 2, 2007 | 04:27 PM
JSPECSIR's Avatar
Default Re: Radiator Fan (HAPRECYCLING)
you can pull the relay in the under hood fuse box, and put a jumper across the 2 rear most terminals. no wire splicing this way.
Old Aug 21, 2021 | 08:52 AM
HardyParty's Avatar
which exact relay kicks on the fan, I believe there is 2 relays...?
Old Aug 21, 2021 | 08:54 AM
HardyParty's Avatar
paper clipped the switch pigtail nothing... AC fan turns on Radiator fan does not.. new fan also installed 15-20k miles ago.. after i replaced thermo the fan stopped turning on, was working fine, turning on just fine... relays fine.. now my fan won't kick after 20mins idle and then a few miles to and from my house fan still didn't kick on.. these civics are weird haha
joelro28
Feb 22, 2014 12:43 PM
gotnos2
Acura TL, RL & ZDX
May 25, 2012 11:23 AM
dudeomega2000
Jan 6, 2008 09:51 PM
dragaholic
Jul 29, 2006 11:43 PM
jetmex
Jul 2, 2005 08:31 AM
