will my old distributor work?
i'm swapping in a complete 93 D16Z6 (with ecu) into my 90 dx hatch. the new engine doesn't have a distributor on it. can i use the distributor off of my d15 on the new engine with the new ecu?
it will work if you use your 88-91 only if you still have dpfi.your stock duel point fuel injection.you need to do the mpfi swap.multi port fuel injection.you need a si ecu 88-91 a distrib from 88-91 civic crx si and the intake manifold ,throttle body, fuel rail, injectors,and the dx to zc or si diagram.
No you cann't use the Dx distributor with the V-tec ECU. You'll be missing the Cyl position sensor and the teeth on the 3 wheel are also different will not work. You can use you DX dis with the DX ecu (my opinion waste of time) or you'll have to get the Z6 dis.
classciv
Apr 2, 2006 03:30 PM
