installing itr .25 over in my gsr block
Old Apr 2, 2007 | 02:56 PM
lakaspeed's Avatar
Default installing itr .25 over in my gsr block
itr .25mm over for my gsr block or itr .30 over
Old Apr 2, 2007 | 04:47 PM
itrSteez's Avatar
Same as every other piston install (after honing your block .25 over), Chiltons manual is your friend!
Old Apr 11, 2007 | 10:10 PM
MindLess311's Avatar
wow i hate when ppl tell ppl they can hone there block to .25 over NO you need to bore at a machine shop then hone it. if you dont know what your talking about dont put your 2cents in. im sry but i dont what this kid to go buy pistons get a honer from the local auto shop and try making these pistons work.
Old Apr 12, 2007 | 02:21 AM
90lsvcrxva's Avatar
Default Re: (MindLess311)
yeah gotta bore it out first>>> then hone. how im doing mine
Old Apr 12, 2007 | 03:38 AM
AllMotorDan's Avatar
I'm having this done too but im not boring because the walls were good and just needed to be Honed.
Old Apr 12, 2007 | 10:51 AM
EGhatch87's Avatar
first off you need to bore the block to met the specs of the pistons, the have the pistons pressed on the rod(machine shop), put the bearings, dont forget the lube, clock the rings put the ring compressor tape them in to place, tq the rod bolts make sure the arrow on the piston is pointing to the front (driveside)...done
Old Apr 12, 2007 | 05:59 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (210EGhatch)
See here.
http://www.redpepperracing.com...a-FSM/
This should help you to get going.
Ryhaz
10
Jan 14, 2014 07:57 AM
all-mtr-teg
17
Aug 29, 2007 01:57 PM
SnOOpY-NO
Jan 12, 2005 08:09 AM
dsosa51
May 24, 2004 10:10 PM
G_Man604
Dec 2, 2003 10:16 AM
